2008 Escalade 6.2 Awd Busted Motor Mount
Old Feb 21, 2015 | 01:09 PM
dr_whigham's Avatar
Default 2008 Escalade 6.2 Awd Busted Motor Mount
River side motor mount is busted, I come to find out. Dealer said 700. I said no thanks.
Has anyone swapped motor mounts on an AWD? How was it? Any advice? I've heard the driver manifold and front axle have to come off.
And just to double check one last time, nobody makes a poly motor mount for these vehicles? I don't know why the hell they wouldn't...
Has anyone used DEA for replacement? How are they?
Thanks in advance.
Old Feb 21, 2015 | 07:31 PM
RS/SS 4.8's Avatar
10 Second Truck Club
Just did a pair (you may as well do both) on the same year esky. I pulled the passenger manifold and was able to wedge the driver side by just removing the steering colum shaft at the racknpinion. Its a pita to get those mounts out on a 4x4/awd but i didnt touch the front diff.
Old Feb 22, 2015 | 07:24 AM
dr_whigham's Avatar
Well that's good news. Only thing I was worried about was pulling the axle. I never have before and wasn't sure how that boot came off.
I take it that it CAN be done on jack stands then? Tools are no issue at all, but I do t have a lift not access to one.
I'll grab the DEA mounts and hope for the best. I'll be doing the trans mount as well.
It still baffles me that with all the options and supercharger kits and everything that NO ONE has grabbed the bull by the horns and made a damn poly mount for these. The driver side tearing is RIDICULOUSLY common.
I figured while I'm in there I'd grab a set of Speed Engineering long tubes and throw them on. I just hope that Y is gonna work with the Corsa Sport. I believe mine is 3.5" and the Y is 3".
I have a feeling I'll be doing some tig welding unless someone has installed these before and can shed some pointers. Maybe that itself needs its own thread...?
Old Feb 22, 2015 | 08:59 AM
RS/SS 4.8's Avatar
Yes it can be done on jackstands and it will help to remove the wheel liners on both sides.
Old Feb 22, 2015 | 01:40 PM
dr_whigham's Avatar
That's planned, yes. It'll definitely make it easier. Probably going to do brakes as well.
This can't be any harder than doing an FBody.
Old Feb 22, 2015 | 07:20 PM
gnasty1521's Avatar
Please take pictures, I would love to see this.
Old Feb 22, 2015 | 09:45 PM
dr_whigham's Avatar
Definitely will do. I usually make my own threads just for these types of repairs. Even CadillacForums really had nothing other than pics of the busted mount. That's great, but it doesn't SHOW me anything.
Once and for all there will be a thread with pics showing what to do.
Old Feb 23, 2015 | 09:43 AM
mjcotroneo's Avatar
I just did mine along with installing longtubes. Same everything. I removed the front drive shaft, removed the manifold, jacked up engine slightly, cut the heat shield so I could access the bolts and it took about an hour that way. Good time go change plugs and check front u joints too.
Old Feb 23, 2015 | 09:47 AM
dr_whigham's Avatar
6spd auto? What long tubes did you go with? Is like to do them while I'm in there as well.
Why did you have to remove the front DS and the intake manifold?
Plugs and wires are already on their way.
Old Feb 23, 2015 | 03:46 PM
dr_whigham's Avatar
So much for ordering brakes.
Apparently there's 2 designs for the front pads in 2008 and the damn dealer can't tell me which one I need w/o seeing it themselves.
I need to go by the caliper bracket casting #...
Looks like I'll be giving it a peek for either 351c/352c or 285/268
