0w-30
Old Apr 27, 2009 | 02:50 PM
Nikon02's Avatar
Default 0w-30
If i go to a 0w-30 would this mess up my active fuel management?
Old Apr 27, 2009 | 08:27 PM
L7 Sierra's Avatar
I venture to say not becouse a cylinoid controls the lifters during AFM.
I would be hesitant to run it again becouse if you start revving your motor up for a bit you can pump all your oil to the top pretty easily. Also I feel the 5 hp you may get is really not worth its problems its been known to have in a normal warm weather car or truck. There's the above pumping all the oil to the top, it can be a nortorious leaker, and it can burn out the tail pipe too easily for me.
All being said I ran it in Gen1 SBC's, and that might of contributed to part of the problem. Even though I took care and built them to run the oil I always found a problem here or there that 5W wouldn't cure.
But if I was in some place cold I would not hesitate using it for a winter oil as which it was deigned for. Not my stupid hot rod fantasy I live.
Old Apr 27, 2009 | 09:51 PM
Nikon02's Avatar
I was thinking the same thing. But i have been doing some research and the only time the 0 should take affect is while the engine is warming up. Once to operating temps it is as thick and protects the same as any other Xw-30 oil out there.
when does the AFM kick in on a cold engine? Prolly once it is warm right?
Old Apr 27, 2009 | 10:04 PM
lukesdad04's Avatar
AFM kicks in at cruising speeds at light throttle conditions. When you apply more throttle or start up a grade it disengages. I can't see how running the 0w-30 would effect the AFM. However what would be gained by running the 0w-30 vs 5w-30??? If in a super cold climate like minus 20 degrees I could see running the 0w-30.
Old Apr 27, 2009 | 10:05 PM
Nikon02's Avatar
i dont think i am going to switch i was just curious. It was bugging me and i wanted to find out for sure.
As far as AFM kicking in i can not get it to go in no matter what till the temp gage is almost to the 210 spot.
Old Apr 27, 2009 | 10:12 PM
lukesdad04's Avatar
I hated the AFM on my truck. Some people seem to like it though. I had mine turned off when I got my first tune. Then I went to the dark side and completely did away with it!!
Old Apr 28, 2009 | 09:34 PM
L7 Sierra's Avatar
I heard of people tuning the AFM with less sensitivity to increase mpg, but they have to have the basics in play for it to work. Also you would need cruise control becouse the foot will never work.
I can get 21-22 when I cruise un-tuned, but I wonder how could I do with a tuned AFM motor with my safe bolt-ons? Maybe 27mpg? I hear a tuned 4.8 with some bolt-ons can do up to 25mpg.
The above figuress you'll keep the 17's with decent tires.
Derek @ EDO
21
Sep 16, 2009 10:32 AM
prince xizor
May 10, 2007 10:00 AM
BirdMan 1585
May 10, 2005 04:42 PM
moregrip
Dec 3, 2004 08:15 AM
