09 Orange Regular Cab Turbo Build
Old Dec 19, 2010 | 01:19 PM
zerotrace992's Avatar
Default 09 Orange Regular Cab Turbo Build - Updated 1-29-11
Ok Sorry for the lack of information at the moment but I figured if I dont get this build thread started now.. I may never since there will be alot of ground to cover when its done.. And I wanted to wait as close as possible to the truck being complete to post.. Which will hopefully be soon. Anyway.
I bought a 09 Regular Cab Red Silverado LT with around 20k on it with a 5.3 and 4l60e trans.
I was just going to put ground effects and other things on the truck... However it since has really gotten out of hand. Here are all the mods that have been or will be done.
---Looks---
-Color change to Orange
-Street Scene Body kit
- Ram Air good hood
-Smooth Se Undercover Bed Lid
-22 Black SS wheels with 305/40's
-Leather Seats
-3 / 7 DJM Lowering kit
-Black Lights all the way around
---Performance---
- DOD Delete
- Rod Bolts & Head Studs
- ls9 Cam
- MP70 Turbo with .96ar
-AEM Meth Kit
-80lbs injectors
-Dual walbro 255 fuel pumps
-Short Corvette style return fuel system
-NGK 3689 plugs
-aem boost gauge
-aem wide band
-Truinnions
-Ls6 springs
-6l90e Trans Swap
- Tru Cool 40,000 cooler
-Caltracs
---Stereo---
-avic-x910bt with backup cam
-Dual Ibeam transducers
-MP Quarts Mid Basses in the doors
-Polk Audio 4x6s and Tweeters
-Dual Pioneer Center Channel Speakers for the onstar / truck sounds and alerts
-Powerbass 2200 watt amp
I am probably forgetting something and if so I will try and add it later.
Truck has now been started... I still need a tune and plan on hauling it to have it turned by bluecat since he isnt all to far away from my location.
Here are a few pics
Before another 2 inch drop in the rear
Again before the truck was dropped another 2 inches in the rear to level it out
Same here Not Level'd
1996lsxS10 's truck doing some Heavy Lifting for 518 Motorsports
If you want more pics check my album here...
https://picasaweb.google.com/Sir.Rya...eat=directlink
Some quick videos..
First Start
[youtube]xZENKh6DRkw[/youtube]
Quick Spool up
[youtube]ht4yiK6K0v8[/youtube]
Engine bay
[youtube]wWi5tqf2DVo[/youtube]
Old Dec 19, 2010 | 01:20 PM
Default Bluecat Tune / Dyno
So the drive-shaft held up for the second trip to Bluecats for tuning..
I cannot say enough good things about this guy.. Or his ls knowledge and tuning skills.. I would have drove twice as far for his tuning services.
Dyno Pull with the drive-shaft staying together under the truck!!!
[youtube]ZI-IwySgdP8[/youtube]
Final Hp Numbers at 10 at psi
just to be safe ill grab this spot too..
Old Dec 19, 2010 | 01:23 PM
blackjack325's Avatar
ah man, thats sick! good luck with your build!
Old Dec 19, 2010 | 01:27 PM
Thanks man.. Like I said with any luck alittle after the first of the year i will have alot more for you guys and it will be tuned and running! I cant wait.. its been a long... long.. process..
Old Dec 19, 2010 | 01:32 PM
iamkeniff's Avatar
LS9 cam? are you going to run a 6.0 with L92/LS3 heads? if not then that cam will be too big of a split for you. just a thought.
truck looks good man. i cant wait to see this thing up and rolling man.
Old Dec 19, 2010 | 01:36 PM
No I am not.. But everything i read seemed to suggest that that cam was perfect for turbo charging..
http://www.lingenfelter.com/mm5/merc...Category_Code=
Old Dec 19, 2010 | 01:48 PM
08cheyennesc's Avatar
Hey do you have a pic of the front of the truck,I want to change my stock hood and I have a procharger so a hood like yours will be perfect,the driver side scoop will actually be right on the blower and filter. Nice truck BTW
Old Dec 19, 2010 | 01:54 PM
As front as I have at the moment sorry.. This was taken a few weeks ago..
