Wind Noise
Old Feb 8, 2013 | 04:27 PM
WanaBquick's Avatar
Default Wind Noise
Hey guys. I hope that this is question was put in the right site. Im kinna new here. But I got a 99 gmc excb and I got terrible wind noise in the doors. Its the first year they put out this new style. Does anyone have ideas for me to try?
Old Feb 8, 2013 | 04:31 PM
nonnieselman's Avatar
Mine is really bad too. ive just learned to live with it..
before goin on a long trip ill grease all the weather stripping and it works for a couple months.
Old Feb 8, 2013 | 06:45 PM
Gadgetized's Avatar
Are your door pins loose? If so replace them. If they are in good shape, find where the loose area is. You can find this by closing the door on a strip of paper with the window down. Grab the paper ends with each hand and slide the paper while marking the loose areas where the gasket is not sealing. Once you have determined where the leaking areas are you can fix it. There are 2 ways to fix it. You can support areas of the door and bend it so that the gasket will be tight. The other method is to build up the gasket area with something behind it. You could use a one sided foam tape to build up the gasket.
Old Feb 11, 2013 | 07:10 PM
Sc00by's Avatar
Truck in sig. I notice wind noise in my truck and a relationship with my A/C controls. My rear windows will make noise if I have my A/C on fresh air and the fan controls turned up around 60% or higher. (digital style ac). When ever I lower the fan controls OR turn my A/C on recirculate the wind noise stops from my rear windows. Im sure the seals are getting old.
Old Feb 12, 2013 | 12:20 PM
1BadAction's Avatar
Registered abuser
I have a wind noise right at the top center of my windshield, but the doors are SILENT. WTFIS that about? I keep my door seals treated with rubber conditioner.
Old Feb 18, 2013 | 01:50 PM
trevorh1's Avatar
is your wind noise from the front door or rear.
Old Feb 18, 2013 | 03:34 PM
kjdmg's Avatar
I have a wind noise around my windshield too, in a 06. I remember my grandpa bought an 03 new and it did the same thing from factory. It's that little black strip around the windshield, it's a pita. I filled mine up with rtv, and it went away.
lukn4trbl355
Oct 21, 2015 11:19 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Velocity1
Oct 2, 2015 08:01 AM
tim wellington
Sep 29, 2015 10:17 PM
