will this 6.0 crank work with my 60e??
Old May 12, 2012 | 01:18 AM
2doorfury's Avatar
Originally Posted by 1Bear
’99-’00 4.8L with a manual transmission & ’99-’00 6.0L with iron heads had the wide flange crankshafts. 6.0L’s from 2001 and up had aluminum heads and the narrow flange crankshaft.
Note the two threaded holes in the adapter. These holes are used to assist in removing the adapter from the crank flange because the register between these two parts can be tight, especially if effected by rust or corrosion.
i did notice the adaptor had threads in it also..im thinking a bolt type balancer puller or steering wheel puller would work.
Old Jun 5, 2012 | 09:16 PM
mopower440's Avatar
I have a 1999 silverado with 4.8 and wanting to upgrade to 6.0, my truck has an automatic 4l6oe, being its a 1999 4.8, would it have the oddball crank in it to where the flexplate from it wont let me use the 6.0?
Old Jun 5, 2012 | 11:12 PM
2doorfury's Avatar
no, the crank in the 4.8 would work. its the 6.0 crank that wont work because its made specifically for the 80e transmission and nothing else.
Go5.3tt06
Sep 12, 2015 09:29 AM
greedygenius
Sep 3, 2015 06:51 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
4B11T
Jul 13, 2015 03:48 PM
GreyChevy
Jul 7, 2015 08:57 PM
