will this 6.0 crank work with my 60e??
Old May 11, 2012 | 02:39 PM
2doorfury's Avatar
Default will this 6.0 crank work with my 60e??
i noticed my 4.8 crank sat almost flush with the rear main seal cover, but the 6.0 crank stuck out a little over a 1/4 inch..it looks like it has sort of spacer on the end of the crank. will my 60e still work with this? can this spacer be removed?.anyone run into this issue?? its a 2006 lq4.
File Type: jpg
Old May 11, 2012 | 02:47 PM
nonnieselman's Avatar
did you try and revmoving the spacer?
It looks like the one that goes between the crank and flywheel.
Old May 11, 2012 | 02:56 PM
2doorfury's Avatar
yes it does go between the crank and flywheel. ive read on here that 04 and up 6.0 cranks are capable with a 60e..but this says different..
Old May 11, 2012 | 03:40 PM
1Bear's Avatar
Just knock the adapter off the rear of the crank and you will be good to go. It was just the factory spacer to allow the use of a 4L80E behind your engine, which must have come from a 2500 or 3500 series.
Old May 11, 2012 | 03:42 PM
2000+ are compatable with the 60E i believe, unless there were some iron head 6.0s in 2000?
Have you tried removing it?
Old May 11, 2012 | 08:54 PM
2doorfury's Avatar
i thought it was 2004 and up that where the compatable ones..i tried getting it off there..didnt really put any effort into it tho. seems like its pressed on. might need a steering wheel type puller to get it off.
Old May 11, 2012 | 10:13 PM
1Bear's Avatar
99-00 4.8L with a manual transmission & 99-00 6.0L with iron heads had the wide flange crankshafts. 6.0Ls from 2001 and up had aluminum heads and the narrow flange crankshaft.
Note the two threaded holes in the adapter. These holes are used to assist in removing the adapter from the crank flange because the register between these two parts can be tight, especially if effected by rust or corrosion.
Old May 11, 2012 | 10:37 PM
la sacred 5.3's Avatar
i had that problem too bro and sorry to tell dont get me wrong but mine i had to sell because i wasnt able to install the mechanic told me that i had to make some other kind of spacer all around the tranny or somthing like that so that my 60e could work i mean thats what he said
Old May 11, 2012 | 10:39 PM
or he also told me just to change the crank
Old May 12, 2012 | 01:17 AM
2doorfury's Avatar
i hope thats not the case..60e's behind 6.0'd are pretty common on here..havent heard of that one yet..hopefully we can get more lq4/60e guys to chime in on this.
