Wierd rear end noise
Old Feb 6, 2010 | 04:12 PM
dirtydog's Avatar
Default Wierd rear end noise
02 Silverado
When I am ALMOST to a complete stop, a vibration/ squeak comes from what sounds like is the rear. Not sure If it brake or not. I know the caliper bracket on the rear right needs replaced, from when I changed the rear pads and rotors about 5k ago. It has made this noise the whole time I have had the truck. Oh and it also does as soon as I take off. Only for a split second, but it is driving me nuts. It is def not the squeal of pads. Any thoughts would be great.
Old Feb 6, 2010 | 08:41 PM
budhayes3's Avatar
PT's Slowest Truck
Rear U-joint maybe?
Old Feb 6, 2010 | 08:52 PM
DV2000NJ's Avatar
13 Second Truck Club
Leaf spring squeak? Try lubricating the spring & shackle bushings.
Old Feb 7, 2010 | 07:40 AM
budhayes3's Avatar
PT's Slowest Truck
That's definitely possible too...is the truck lowered? Sometimes the leaf spring bushings will give you a squeak. This can often times be cured by loosening the leaf spring mounting bolts and re-torquing them, while the truck is on the ground with all of it's weight on it.
Old Feb 7, 2010 | 11:24 AM
hirdlej's Avatar
Do you have a regular cab or extended cab? My regular cab was doing this when the support cables were installed.
Old Feb 7, 2010 | 02:51 PM
dirtydog's Avatar
It's not lowered. It is a extended cab Z71. All OEM except shocks and it did that long before the shocks were installed. I will try lubing the shackles and what not. I would think if it were the u joint it would have gone out by now, I have put about 40k on it while making the noise. Which support cables were referring to?
Old Feb 8, 2010 | 03:20 PM
Beatdown Z's Avatar
Laid Back
slip yoke? try greasing the splines of the slip yoke
Old Feb 15, 2010 | 07:32 PM
dirtydog's Avatar
Yeah, I did some research on the slip yoke, I think that is probably it. It will have to wait for some warmer weather since it is cold as ***** here right now and I have no garage.
pjb1972
Sep 17, 2015 02:06 PM
TimDave217
Aug 24, 2015 04:38 PM
vipergtrdj
Aug 6, 2015 10:19 PM
shupe
Aug 5, 2015 06:45 PM
Ketis
Jul 23, 2015 12:37 PM
