Wierd rear end noise
02 Silverado
When I am ALMOST to a complete stop, a vibration/ squeak comes from what sounds like is the rear. Not sure If it brake or not. I know the caliper bracket on the rear right needs replaced, from when I changed the rear pads and rotors about 5k ago. It has made this noise the whole time I have had the truck. Oh and it also does as soon as I take off. Only for a split second, but it is driving me nuts. It is def not the squeal of pads. Any thoughts would be great.
That's definitely possible too...is the truck lowered? Sometimes the leaf spring bushings will give you a squeak. This can often times be cured by loosening the leaf spring mounting bolts and re-torquing them, while the truck is on the ground with all of it's weight on it.
It's not lowered. It is a extended cab Z71. All OEM except shocks and it did that long before the shocks were installed. I will try lubing the shackles and what not. I would think if it were the u joint it would have gone out by now, I have put about 40k on it while making the noise. Which support cables were referring to?
TimDave217
Aug 24, 2015 04:38 PM
shupe
Aug 5, 2015 06:45 PM
