Why is it bad to hit the rev limiter?
Old Mar 19, 2011 | 05:56 PM
silverado2000's Avatar
Default Why is it bad to hit the rev limiter?
Ive seen some threads about this and im wondering why you guys think its bad to hit the rev limiter? I never rev my truck to the limiter, but all it dose is cut spark when you do so why dose everyone think it's so bad. Its not like your valves are floating or anything.
Old Mar 19, 2011 | 06:06 PM
Atomic's Avatar
I have a gauge for that
Well as long as the rev limiter is within the operation limits of the engine there really isnt much immediate risk....but if you sit there and bounce it off the rev limiter for a few minutes you are going to be really stressing components, and especially the cooling system.
Old Mar 19, 2011 | 06:15 PM
Thats how i feel about it, but in a couple threads people were saying others were dumb for hitting the rev limiter.
Old Mar 19, 2011 | 06:16 PM
Atomic's Avatar
Well you shouldnt ever need to if your shift points are set correctly...its there to prevent the engine from over-revving.
Old Mar 19, 2011 | 06:23 PM
Mangled03gmc's Avatar
Baltimore Whore
Also causes alot of stress on the timing chain
Old Mar 19, 2011 | 07:55 PM
budhayes3's Avatar
PT's Slowest Truck
+1...
I thought that it cut fuel...if the PCM cut spark, raw fuel would dump into the cat converters...
Old Mar 19, 2011 | 08:15 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
If you're bouncing off the rev limiter, you are not accelerating.
Old Mar 19, 2011 | 08:23 PM
dewmanshu's Avatar
Moderately Differentiated
yep, cuts the injectors.
think of that rpm and how fast stuff is moving at that point with all that force behind it and then off and then on and then off and then on, all those cycles at 6500rpm instead of 1500rpm. LOL It just sounds bad. Salck in timing chain, no slack, slack, no slack...ugh. Not what the engine is desgned to do. I have no room to talk, but I accept it can't be good.
Old Mar 20, 2011 | 12:07 AM
good points i did not think about the timing chain. well i guess that kid was dumb for driving around and hitting the rev limiter for fun haha
Old Mar 31, 2011 | 08:49 AM
kr1s's Avatar
I always hear little tuners doing that, then they get spanked by my stock tahoe
