Who makes a starter suited for higher CR engines?
Old Jan 23, 2011 | 04:53 AM
1SlowHoe's Avatar
Destroyer of Transmissions
Default Who makes a starter suited for higher CR engines?
I broke the corner of of my starter awhile back when I torqued the bolt too much. It still holds and works fine but I figured I might as well get a new one when I swap in my 408.
I'm going up in compression to 10.5:1. Will an OEM starter but up for the task? I figured I'd just get a starter with more Tq if there is one available.
Thanks!
Old Jan 23, 2011 | 05:03 AM
1SlowHoe's Avatar
Don't make me buy from eBay...
http://cgi.ebay.com/ebaymotors/Ls1-L...Q5fAccessories
Old Jan 23, 2011 | 08:53 AM
Country Boy's Avatar
Senior Member
Stocker will be fine. I had my stocker when I was ~11.3:1.
Old Jan 23, 2011 | 09:34 AM
dirt track racer 81's Avatar
When my 5.3 blew up it took out my starter and I put an ls1 starter on my 6.0 when I put it in. The last set of heads on my 370 the compression was 11.5:1 and it turned over just fine with no problems at all. I'd like to know if sbc starters are the same as ls1 style starters. I've got a cheap mini starter from smileysracing.com 7 years ago that's was on my 13:1 355 and 14.5:1 377 with no problem.
Old Jan 23, 2011 | 01:51 PM
1SlowHoe's Avatar
Ok, so the OEM will be fine. I see OEM's for sale at $100 or so up to $160. If I can pick up o high tq starter for the same and even cheaper I don't see any reaon not to...do you?
Old Jan 23, 2011 | 02:32 PM
skeet's Avatar
if you can get a higher torque starter for close to the same price i would go that route, but the OEM starter would be fine
Old Jan 23, 2011 | 02:39 PM
Atomic's Avatar
I have a gauge for that
Yep, used my stock starter on my 11:1 408 with my blower
Old Jan 23, 2011 | 02:49 PM
offroadrider12's Avatar
MSD makes the APS starter for high comp ls engines.
steves86ta
Jul 28, 2015 10:21 AM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
FlowmasterMufflers
Jul 22, 2015 12:47 PM
FlowmasterMufflers
Jul 17, 2015 03:26 PM
bsn1989
Jul 16, 2015 08:20 AM
