High idle
Old Jan 18, 2011 | 05:59 PM
95greenZ's Avatar
Default High idle
Hey guys I'm a new member here, I bought a 03 Silverado couple weeks ago. Anyway over the weekend I cleaned the throttle body and now it idles a little high, and when I come to a stop it takes a few seconds before the rpms will come down. I did take the throttle body off to clean it so I guess the gasket may not be sealing. Or could it be the electronic throttle body? Any ideas?
Old Jan 18, 2011 | 06:27 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
sounds like an air leak....
Old Jan 18, 2011 | 07:35 PM
terravast4's Avatar
did you reconnect the hose from the passenger valve cover to the intake tube?
Old Jan 18, 2011 | 08:07 PM
dewey04's Avatar
recalibrate the throttle body
Old Jan 18, 2011 | 08:46 PM
95greenZ's Avatar
I don't remember a hose being there, but I'll double check.
How exactly do you do that, tuning software?
Old Jan 19, 2011 | 09:17 AM
dewey04's Avatar
First check for air leaks. Spray carb cleaner around the intake and throttlebody with the truck running if the idle picks up you have a vacumm leak. If that does not work and you do not have a scan tool that will recalibrate the throttle body un hook the battery negative for 10 min. that will allow the computer to reset. it will usually take a day for the computer to re learn the air fuel mixture and then resume running normal. Also get a can of mass air flow cleaner and clean the mass air flow sensor if you have some miles on the truck.
Old Jan 23, 2011 | 08:54 PM
05gmcsierra's Avatar
ive done this also and the same thing has happened to me... u just need to drive around and wait for the computer to relearn the idle.. im assuming since u cleaned it its getting more air causing it to idle high.. mine usually takes about 1 full day of driving around till it adjust itself and comes back to normal.. but idk it might be something else..
Texas5.3_1251
Mar 5, 2016 08:10 PM
gmcyukon
Sep 11, 2015 10:33 AM
cousblake11
Sep 9, 2015 06:52 PM
Pimpinpete
Sep 8, 2015 07:39 PM
custm2500
Sep 8, 2015 05:53 PM
