What is the shelf life of oil???
Old Mar 7, 2005 | 01:02 AM
Mr. Sandog's Avatar
Originally Posted by desTRUCKtive
I emailed Valvoline, i hope they will respond, but have you guys ever noticed that there is an experation date on Dot 3 brake fluid.
Brake fluid is different, very volatile from what I understand (i.e. no plastic containers, metal only - moisture absorption is an issue, etc.)
Old Mar 7, 2005 | 08:31 AM
desTRUCKtive's Avatar
here is the answer to the question, Strait from valvoline:
Thank you for your question! The Valvoline Company does not have a documented shelf life exposure on finished motor oil. We would expect
under optimal conditions that the product would be stable for an extended
period of time.
Old Mar 7, 2005 | 12:28 PM
hirdlej's Avatar
That's awesome!!!! I just went in the back garage and you'd think I own stock in Pennsylvania oil company I just took inventory of what I have and it turns out I have 5 cases of penz 5w-30 and 5 cases of penz 10w-40 and 18 cases of Quaker State 5w-30 and 2 cases of 10w-30. Thought i was going to have to ebay it off before it expired LoL Guess I can keep on truckin then
Old Mar 8, 2005 | 08:39 AM
In some cases the additives will fall out. But it's no big deal if you shake up the quarts before you use them.
With that much oil you might want to ebay some of it off.
you have enough for about 50 oil changes and if you change it 4 times a year it's going to take over 10 years to use all of it.
Old Mar 8, 2005 | 11:56 AM
kbracing96's Avatar
Ever think of starting a quick lube
Old Mar 8, 2005 | 12:28 PM
hirdlej's Avatar
That's good!!!
Actually I travel about 18,000-20,000 mi/year on my silverado alone and 2,000 a year on my 70 C-10. The Silverado gets religious oil changes every 2,000 miles regardless of the driving style. Many may say that this is a waste of oil but I drive the **** outta my stuff and I've always been a firm believer of keeping clean oil in at all times along with keeping your motor well tuned (no misfires) and you should be able to drive it as hard as you want without damage. Also keeping it cool is obviously a large factor as well. Anways, at a rate of 9 or 10 oil changes per /yr in the silvy, then my C-10 gets 1,000 mile oil changes. The reason for that is it's a 500HP 468 that when driven at highway speeds (75MPH) sits at only 3800 RPM's Tat along with only a 5qt oil pan, you're better safe than sorry keeping the oil clean in that along with the heat stress put on the oil by that big block
Joe
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
1_fastsilverado
Oct 11, 2015 11:34 PM
sTNT971
Sep 26, 2015 04:22 PM
lxcoupe
Sep 25, 2015 12:36 PM
