what is this on my fuel pump?
Old Jul 17, 2010 | 12:26 AM
Daryn's Avatar
Formerly darynC-10/23/10
Default what is this on my fuel pump?
it looks like a big filter ... its not really connected to anything besides the fuel pump outlet... can i do away with it ? my 255's wont beable to fit with that big stupid contraption in there!
BUMP! i just bought this bad boy!!!
http://www.jegs.com/i/Aeromotive/027/13109/10002/-1
Old Jul 17, 2010 | 03:14 PM
Gadgetized's Avatar
That appears to be your filter regulator assembly. Yes you can do without it, but you will neeed to install another one out of the tank. I just installed an adjustable regulator, and replaceable filter on the inside of my frame rail. It turned out pretty nice. If I was running dual pumps, I would consider not using the stock regulator. I am not sure how much fuel volume it is able to regulate.
Old Jul 17, 2010 | 04:06 PM
Daryn's Avatar
i will be running 2 pumps so takin this out will help alot. theres no wires hooked up to it so i dont see how it could be a regulator. i may get the corvette regulator that goes inline with the fuel system
Old Jul 17, 2010 | 09:08 PM
Gadgetized's Avatar
A regulator does not contain wires. A regulator is operated by a spring. It just basically bleeds off excess fuel pressure from the fuel line back in the tank.
Old Jul 17, 2010 | 09:11 PM
Gadgetized's Avatar
Also, I would suggest to get an inline regulator. You don't have to run a Corvette regulator, any fuel injection compatible regulator will work. You will also need to run a filter, I just used a NAPA 3481.
Old Jul 17, 2010 | 09:15 PM
TurboGibbs's Avatar
If you have an external regulator you will have to have a return line back to the tank.
Old Jul 17, 2010 | 11:17 PM
fredkj3's Avatar
get an adjustable one if its gonna be outside the tank...
Old Jul 18, 2010 | 02:06 AM
Daryn's Avatar
i plan on running a return style fuel system..
i have to gather some aluminum so i can make me a fuel cell!
Old Jul 18, 2010 | 02:08 AM
Bumpers's Avatar
Looks like a flux capaciter to me for time travel
Old Jul 18, 2010 | 02:24 AM
Daryn's Avatar
oh i also put air to one side and a bunch of dirt and crap came flying out!.. yuck!
