what is this on my fuel pump?
Formerly darynC-10/23/10
it looks like a big filter ... its not really connected to anything besides the fuel pump outlet... can i do away with it ? my 255's wont beable to fit with that big stupid contraption in there!
BUMP! i just bought this bad boy!!!
http://www.jegs.com/i/Aeromotive/027/13109/10002/-1
That appears to be your filter regulator assembly. Yes you can do without it, but you will neeed to install another one out of the tank. I just installed an adjustable regulator, and replaceable filter on the inside of my frame rail. It turned out pretty nice. If I was running dual pumps, I would consider not using the stock regulator. I am not sure how much fuel volume it is able to regulate.
i will be running 2 pumps so takin this out will help alot. theres no wires hooked up to it so i dont see how it could be a regulator. i may get the corvette regulator that goes inline with the fuel system
Also, I would suggest to get an inline regulator. You don't have to run a Corvette regulator, any fuel injection compatible regulator will work. You will also need to run a filter, I just used a NAPA 3481.
