what else can i do?
Old Apr 24, 2006 | 10:33 AM
  #41
Post
Originally Posted by tdrumm
I was told that it is a 60" belt for the short belt trick.
If it is 60" then there are two numbers in the part number of the belt that will have 60 in it. That should help some of you figure it out.
Jim
Old Apr 24, 2006 | 02:09 PM
  #42
ap2002's Avatar
errrr, i lost the box to it. all i know is the part number listed in the forums wasnt the right size for my truck. i just went to one of my budies at o-reily and started putting random belts on till we got it right.
so when you get your UD pulley you will need a different size belt to do the short belt trick??? if so, then you want to sell me the current one that you have, it should work on mine if I still have the stock UD pulley right??
Old Apr 24, 2006 | 02:26 PM
  #43
Injected1's Avatar
I would tell you a better converter like a Fuddle...Transgo Shift kit remove more TM, and race gas with more timing...Cometic Head gaskets to raise compression, some roller rockers might be nice...
Old Apr 24, 2006 | 03:32 PM
  #44
TXsilverado's Avatar
how much would it raise it and what would it be worth powerwise? i already plan a transgo and 100% tm loss, just dont have the time with school and all. i like my trailblazer stall, but want more stall from it now. 3000-3200 sounds comfortable. i think ill just get it restalled.
Old Apr 24, 2006 | 03:54 PM
  #45
bluecajun5.3's Avatar
11 Second Truck Club
with the stock crank pulley the shortbelt is 60" like stated by tdrumm.
i believe with the u/d pully the shortbelt is 55", i'm not positive though.
all you do when you go to the parts store is tell them the length for your application and how many ribs/grooves wide. ex: 60" long, 6 ribs/grooves wide. i got mine from advance auto for $10.
i can tell you first hand tests, i gained 10hp/10tq across the board on the dyno w/ the shortbelt. (that's with the stock pulley too).
also last wed for t&t, for the 1st pass i left the stock belt on and the pass headlight in. 1 hour later, for the 2nd pass i put the shortbelt on and removed the pass headlight, and what do you know i picked up exactly 2/10's and 1mph. no b/s here.
Old Apr 24, 2006 | 04:40 PM
  #46
i saw where someone shortbelted but kept the alt in the loop because the underdrive pulley gave them the clearence. anyone know what size belt i would need for that....and how i would need to run it
Old Apr 24, 2006 | 05:07 PM
  #47
i did a search on it a long time ago. someone had posted pics of the u/d pully w/ the shortbelt ran to the alt. pulley. i'll try and find it.
Old Apr 24, 2006 | 05:23 PM
  #48
found it tx. here it is...
https://www.performancetrucks.net/fo...ght=short+belt
Old Apr 24, 2006 | 05:37 PM
  #49
stone150's Avatar
what is the point of adding new rockers?
all i can say is, if i ran a 13.8 i'd be happy that's faster then my t/A
Old Apr 24, 2006 | 07:42 PM
  #50
Question
Do you have to use the alternator in belt loop? Was just curious because I would think the battery would be able to withstand a single 1/4 run without having a loss in amps going to the plugs. The alt does create quite a bit of drag when it is in the load or charging cycle.
Jim
