what causes this...
Old Sep 26, 2009 | 01:28 PM
vortec-dude's Avatar
Default what causes this...
Recently, I started noticing that when I lower my powered windows, I hear this annoying squeeky noise, all the way till it stops, but when raised, the squeekyness stops. Not sure if its the glass or the motor. Any ideas what is causing this? Thanks in advance
-Luis
Old Sep 26, 2009 | 02:04 PM
1blueSS's Avatar
formerly 1fstrst (11/25/2010)
Just pop off the door panels and spray down the window trac with some white lithium spray. its a good place to start. my buddy owns a body shop and he says usually that will fix the squeak.
Old Sep 26, 2009 | 03:09 PM
Appreciated man! I will be trying this out as soon as possible. The lithium spray...do they sell this in any autoparts store?
Thanks again.
Old Sep 26, 2009 | 03:16 PM
1blueSS's Avatar
yea any autoparts store will carry it. you will need to wipe off the overspray that gets on the glass. run the window up and down a few times you might need to spray it a few times but the prob should go away
Old Sep 27, 2009 | 10:41 AM
budhayes3's Avatar
PT's Slowest Truck
Check the belt mouldings also (the felt things that ride against the window, at the base of the window on the outside and inside). Often time, dirt and stuff builds up on the belt mouldings and may cause squeaks when the window is operated. Unfortunately, there's really no lube that you can spray on them or the window will get coated, just try to clean them off real good. Usually it's the outer one that will give you problems...
InsaneDomestics
Jul 27, 2015 02:42 PM
dewmanshu
Sep 28, 2007 03:03 PM
203Cree
Apr 19, 2007 10:37 PM
crazyidiot4.8
Mar 20, 2002 07:33 AM
