which vehicles can use E85 gas?
Old Jul 23, 2006 | 12:43 PM
dry_kill's Avatar
Default which vehicles can use E85 gas?
My mom wanted to know this and I didn't know so I figured I'd ask on here? Which vehicles can use the new E85 gas? Is it all vehicles or is it just some vehicles?
Old Jul 23, 2006 | 12:47 PM
BlackLM7's Avatar
Only some vehicles with the 5.3 engine. I believe you will see "E85" on the RPO code list in the glove box if the vehicle is flex-fuel. Check to see if the gas cap is green...it's an E85 vehicle if it is.
Old Jul 23, 2006 | 01:00 PM
dry_kill's Avatar
o ok, well i doubt she can use it, she drives a 98 tahoe
Old Jul 23, 2006 | 01:34 PM
nightrunner's Avatar
Mr. Obvious
i think most vehicles CAN use it but is not advisable
i think the only differnece between e85 and nonE85 engines is some fuel hoses because the ethanol in the fuel causes the standard hoses to decompose or break down
if used for long peroid of time it would break down fuel hoses
NOT ADVISABLE
Old Nov 10, 2006 | 10:52 PM
SSRZ28's Avatar
so its just hte hoses. the actual engine is the same for both the L59 and LM7 5.3 liters?
Old Nov 11, 2006 | 07:30 AM
Grumpy5.3's Avatar
NOT ADVISABLE
NO!!!! do not run E85 in a non-E85 vehicle it will run like $HIT the computer has to learn the octane rating and adjust accordingly.... yes the hos are diffrent but the fuel system and settingsre way diffrent!!!
Old Nov 11, 2006 | 10:58 AM
foxracingfreak's Avatar
yeah im with grumpy... if you run E85 for long periods of time it will screw stuff up... my truck is a 5.3 flex fuel but i have not ran it in it. and about the gas cap mine is not greem
Old Nov 11, 2006 | 11:00 AM
MikeGyver's Avatar
Don't worry, the engine won't stay together long enough to damage the hoses.
dantheman1540
Sep 15, 2015 08:28 PM
FlowmasterMufflers
Sep 11, 2015 03:32 PM
GM1697
Sep 9, 2015 10:31 PM
GM1697
Sep 9, 2015 01:52 PM
