Using a TCM-2650
#52
Oh good God. I have heard some WILD stores about Havasu over the years. Sounds like a good time. lol
arthursc2 (12-17-2021)
#54
I plan to do the 6L90 with TCM-2650 setup this summer God willing.
My 4.8/4L65e currently.
Plan is SBE 4.8 with a 6L90 Trans this summer 2022.
Then Fall 2022 would be LSA Swap with LS9 Cam and headers.
2/4" MaxTrax Drop w/spindles & flip kit GMPP 6 Piston 16" Front Brakes Corvette 4 Piston Rear Brakes GM High Country 22" Wheels
#56
Please document whatever you come up with @banks53
The internet is missing some high quality info on this swap to make it super popular (unless it is just way to expensive to be reasonable in the end).
I’m finding it hard to find a v8/6L80 harness in tact.
#57
The following 2 users liked this post by shakenfake:
banks53 (01-20-2022),
wretched73 (01-20-2022)
#58
@firebladeJJ Hurry up and start the swap so I can come over and document this **** for you
arthursc2 (01-20-2022)
#59
Yes bitch it is broke but I don't have the 6L80 to swap in nor all this other shtuff. It's getting warranty repaired if you read my other post last night
I love casting couch.
firebladeJJ (01-20-2022)
#60
So I already have a 6l80 4x4 trans that we are doing a 80/90 rebuild on. So that’s moving.
Plan is to use a 5th gen Camaro ZL1 converter.
Issue I am finding is info on if the stock 07-13 transfer case (3023LD NQH) will:
1) bolt up to the 6L80/90
2) t-case input / trans output spline info. Will the t-case input need changed? I’ve seen conflicting information about 27, 29 and 32 spline for 07 Silverados with a 3023 t-case.
obviously the following will need custom mods:
1) front prop shaft
2) rear drive shaft
3) trans cross member.
1) front prop shaft
2) rear drive shaft
