Using a TCM-2650
Old Nov 1, 2021 | 08:55 AM
firebladeJJ's Avatar
Default Using a TCM-2650
Has anyone on HERE successfully used the controller in the title to swap in a 6l80? I have questions.
I'm toying with the idea of ditching the T56 swap for the 6l80. I like having 6 speeds in the truck, i also like rowing the gears too but it seems I'm always running into issues with the t56 or some component and I drive the truck daily.
Old Nov 1, 2021 | 10:56 AM
tjmath's Avatar
@arthursc2 has been working on doing a 6L80 swap for a while... not sure he has actually gotten anywhere yet since he has eleventy billion other projects at the same time.
Old Nov 1, 2021 | 11:03 AM
shakenfake's Avatar
Shlumpt
5 Year Member
Someone needs to go down there and just stand there with a gun and force arthur to finish. The 6L80 swap would be ****
Old Nov 1, 2021 | 11:15 AM
thats who it was, i couldnt remember some on here was in the process of doing it. Maybe he'll chime in later.
Old Nov 1, 2021 | 11:16 AM
I may just start collecting parts now, I dont have many projects right now, just kids, thats just as bad.
Old Nov 1, 2021 | 12:11 PM
arthursc2's Avatar
Y'all some haters 😂😂
I have the trans and controller and documentation. I can scan the documents/ wiring diagram in if you'd like
I remember Jim saying the TCM needs TPS/RPM inputs and it has its own OBD port to tune it. HPT can tune it
Also Jim ships it with a base calibration to make it drivable
Stock LS 4L60 flex plate is reused and you need a 32spline t case
Although I guess you're 2wd
I'll around to it. I have some hang ups because I like doing things 1x only. So I started thinking about a new motor, integrating my solid swap into the trans cross member and redoing the interior since I have another controller and wiring to hide
since the 4L60 still works, I'm just pushing it off as far as possible
Old Nov 1, 2021 | 12:44 PM
Sorry they are picking on you but if you're going to do great things, you can expect it! LOL
Yes, when you have time, if you could send any documentation my way, I'm not in a huge hurry to do this. It will probably take me a year to collect parts.
I'll take a look at the wiring and stuff, that will probably answer most of my questions.
And yes my truck is 2wd.
Thank you!
Old Nov 1, 2021 | 01:31 PM
arthursc2's Avatar
I too also take years to get anything done lmao
Old Nov 1, 2021 | 04:07 PM
tjmath's Avatar
Anything except reply to posts
Old Nov 1, 2021 | 04:19 PM
arthursc2's Avatar
You know man, sometimes I'm bored lmao
