Upper Intermediate Shaft & Lower Column Bearing Questions
Old Aug 8, 2015 | 02:10 PM
AUTOT3K's Avatar
Default Upper Intermediate Shaft & Lower Column Bearing Questions
hey guys
on my 06 silverado ECSB 4x4 /w 4.8L and 4L60E
I'm getting the infamous clunking / column rattle when turning and going over bumps. I've hit google and read through lots of other forums and havent found a good or direct answer.
has anyone had luck with the updated Dorman 905512 (GM 88963617) Green bearing?
has anyone had luck with the updated Dorman 425176 (GM 19153614) Upper Intermediate Shaft?
Every thread I read through, one guy had it come back after 2 months, another guy gets 20k and it comes back etc etc. I havent seen anyone replacing both at the same time, would that be a good idea?
Old Aug 8, 2015 | 03:06 PM
01SilvyZ71's Avatar
Just replaced both of those in my dads 04 tahoe with 130k miles, havent gotten to drive it yet but i hope they last longer than 20k miles. If it was me i would replace both while im in there.
Old Aug 8, 2015 | 03:11 PM
01SilvyZ71's Avatar
Here's some pictures I took to show the differences in the upgraded parts
Attached Thumbnails Upper Intermediate Shaft & Lower Column Bearing Questions-imag0625.jpg   Upper Intermediate Shaft & Lower Column Bearing Questions-imag0626.jpg   Upper Intermediate Shaft & Lower Column Bearing Questions-imag0628.jpg   Upper Intermediate Shaft & Lower Column Bearing Questions-imag0627.jpg   Upper Intermediate Shaft & Lower Column Bearing Questions-imag0624.jpg
Old Aug 8, 2015 | 03:13 PM
01SilvyZ71's Avatar
Bearings...
Attached Thumbnails Upper Intermediate Shaft & Lower Column Bearing Questions-imag0619.jpg   Upper Intermediate Shaft & Lower Column Bearing Questions-imag0616.jpg
Old Aug 8, 2015 | 03:18 PM
AUTOT3K's Avatar
Definitely quite the upgrade.
Are those the gm upgrade or the dorman ones?
Old Aug 8, 2015 | 03:23 PM
01SilvyZ71's Avatar
Dorman, figured GM couldn't make it right the first time so might as well try aftermarket.
I need to replace both in my 03 so I might put in GM parts to see how they hold up I'll keep you posted.
Old Aug 8, 2015 | 06:41 PM
AUTOT3K's Avatar
Thats a good call about gm crapping the bed first time around haha.
Did the bearing just pop out once the upper shaft was removed?
Did you have to remove your gas pedal?
Old Aug 8, 2015 | 06:50 PM
1FastBrick's Avatar
Custm2500's Rude Friend
The Dorman Is just a reboxed part. Its probably from the same vendor that makes it for AC Delco.
Old Aug 8, 2015 | 07:21 PM
skolman91's Avatar
I first replaced the bearing with the green one a few yrs ago, then went to a dorman shaft which was at least a yr ago if not 2. Its just now ever so slightly starting to clunk again when making turns and hitting bumps, also seems to depend on the temp outside how bad it does it imo..
But yes it will come back eventually, but worth it not having the shitty gm shafts in there. The bearing will just pop off the end of column once the int shaft is removed iirc. Im also staring to get some play in what feels like right behind the wheel which im assuming is the upper most bearing in the column, which id imagine wont be fun to replace..
Old Aug 8, 2015 | 07:47 PM
01SilvyZ71's Avatar
I moved my gas pedal so I could have a little more room to work with. Had to persuade it in and out with a hammer, screw driver, and some lithium grease. Struggled with it a little bit.
