underdrive pulley question
Old Feb 1, 2007 | 04:52 PM
00stepsyde's Avatar
Default underdrive pulley question
Hey guys, I just ordered a set of ASP underdrive pulleys, my question is has anyone had any problems with charging after intalling them. I have 2 amps in the truck, and I dont want to have any problems once I install them. Also does anyone have any before and after numbers from just the pulleys. I am going to be installing a TR 220 cam and springs at the same time so I wont be able to see if the pulleys really helped or not. Thanks!!
Old Feb 1, 2007 | 04:54 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
Did you order the overdrive pulley for the altenator? You'll want it.
Old Feb 1, 2007 | 04:57 PM
bluecajun5.3's Avatar
11 Second Truck Club
either that or upgrade to a 145 amp alt like i did.
Old Feb 1, 2007 | 05:05 PM
00stepsyde's Avatar
yes I got the kit that comes with the smaller Alt pulley, so with that I should be ok.
Old Feb 1, 2007 | 05:10 PM
think about it.
the smaller alt pulley is like the (smaller) crank pulley that slows down your accessories.
so a smaller pulley on the alternator is going to create less charge.
am i on the right track guys?
Old Feb 1, 2007 | 05:14 PM
00stepsyde's Avatar
I dont know maybe the alt pulley is larger, the kit said it would compensate for the smaller crank pulley, and turn the alt faster. I just dont want to have charging issues. Is the 145 alt just a plug and play installation?
Old Feb 1, 2007 | 05:21 PM
yes the 145 amp is plug and play.
Old Feb 1, 2007 | 10:26 PM
alanderson1978's Avatar
The smaller pulley on the crank makes the belt move slower (The outside of the pulley is smaller, so the belt moves less for each revolution), slowing down accessories. The smaller pulley on the accessories make them turn faster (The outside of the pulley is smaller, so the accessory turns more for the same distance of belt movement)
N1*D1=N2*D2
N1 = Crank speed
N2 = Accessory speed
D1 = Crank pulley diameter
D2 = Accessory pulley diameter
Old Feb 2, 2007 | 01:57 AM
CashDudeHomie's Avatar
This guy is right^
Layn22s
Aug 31, 2015 03:43 PM
wrb002
Aug 25, 2015 03:56 PM
Bluchevypick
Aug 18, 2015 09:11 AM
USMCvet0311
Aug 1, 2015 07:45 AM
bigsapper
Jul 28, 2015 12:56 AM
