True Trac ?
Old Jan 8, 2008 | 11:45 AM
  #31
beastmode's Avatar
Import Moderator
Originally Posted by 20032wdsilverado
how would 4.56s run in a 4l60e and with 35 inch tires?
dunno for sure but you might wanna go wit 4.30s
Old Jan 8, 2008 | 12:13 PM
  #32
agreif's Avatar
Just to clarify, the stock G80 works on a speed differential. So if you have one tire in snow and the other on pavement, the one on snow will initially spin with the pavement one stopped until there is a speed difference detected, then the two are locked together, so creeping along at low throttle is possible. For a trutrac or eaton posi with clutches, it worked on torque input. So with the same scenario at light throttle you will only have enough torque to drive one wheel, but when you get into the gas and increase the torque output of the engine both wheels will turn together. up here in NY, the G80 would be nice in the snow from a stop as right now I have to get into it to get them to both spin, but you can't beat the posi/trutrac in the dry conditions.
Cool video basically showing the slow speed differences between the two styles, posted from pacificp.com.
Cool demo of the G80 vs the limited slip in the jap truck...
http://www.youtube.com/watch?v=Z8PpZF77tgk
Old Jan 8, 2008 | 12:43 PM
  #33
regency's Avatar
Originally Posted by TurboGibbs
The heavy duty covers are a must with a manual IMO. The jack bolts that contact the carrier brg caps along with the cover provide support to keep the pinion from seperating from the ring gear under heavy loads like clutch dumps. When the ring and pinion push away from one another they mesh on the outer edge of the teeth and break.
well i have a A4 i understand what your saying about seperation so i might just get one later and get this thing installed right now bc the g80 is pissing me off
Old Jan 8, 2008 | 03:24 PM
  #34
TarheelZ's Avatar
Originally Posted by regency
...i like the TA but its so damn expensive for looks really. what other covers are out there a lil cheaper and is the stud kit for the caps worth the swap also.
I'd say yes, definitely worth the swap. Stud kit + cap = peace of mind.
Old Jan 8, 2008 | 05:32 PM
  #35
bgray's Avatar
TOTM: June 2007
stud kit and cap???? inlighten me with soem links...my tru trac and yukons jsut arrived
Old Jan 8, 2008 | 05:57 PM
  #36
regency's Avatar
stud kit is arp studs/washers/nuts in place of the stock bolts for the main caps. and the cap is the cover or rear diff cover. i know you know what were talking about you just had a brain fart itll be alright
Old Jan 8, 2008 | 05:59 PM
  #37
BlackGMC's Avatar
Resident Retard
So why are studs and nuts better than bolts? I noticed alot of guys use studs on heads rather than bolts...
Old Jan 8, 2008 | 06:32 PM
  #38
regency's Avatar
basically all i can tell is that they have a finer thread which means it can get tighter, and the studs wont stretch like a bolt would under heavy torque
Old Jan 8, 2008 | 07:38 PM
  #39
TarheelZ's Avatar
One of the things I really like about the TA Performance cap that I have (besides the quality) is that it has the two external load bolts to tighten against the bearing cap. Considering some of the hairy-assed Buick chit (http://www.hotrod.com/techarticles/e...ock/index.html) that TA Performance is known for, I think they're definitely worth the extra $$$, especially for BIG power.
Old Jan 8, 2008 | 09:09 PM
  #40
bgray's Avatar
TOTM: June 2007
some part numbers for the Cap and stud kit...by cap are you referring to the ENITRE diff cover, or just a internal brace?
