True Trac ?
Old Jan 2, 2008 | 04:54 PM
TurboGibbs's Avatar
mine locks if i give it any real throttle at all...wet or dry.
I know what your saying. To me it is just the same resistance you get with a clutch type posi. They all are a little dangerous in the rain due to both tires getting even power and both loosing traction at the same time.
Old Jan 2, 2008 | 06:13 PM
bgray's Avatar
TOTM: June 2007
I think you mean a little Fun
Old Jan 2, 2008 | 07:53 PM
texastahoe's Avatar
+1 for the truetrac, so far it's been flawless
Old Jan 4, 2008 | 03:50 PM
brodystruck's Avatar
Yal guys chirp the inside tire going around a turn? If you're turning and a tire gets into some gravel does it start spinning immediately?
My damn Powertrax locker is pissing me off. If the rear-end isn't 100% smooth it throws out and puts 100% of the power to the driver's side wheel. Didn't used to do this, only recently (maybe worn out springs)...
Old Jan 4, 2008 | 04:30 PM
KevinF56's Avatar
if i give my truck any decent power around a turn it'll chirp the inside wheel. i dunno about the gravel scenario... i assume it'll spin and catch up to the outside wheel.
Old Jan 4, 2008 | 04:34 PM
BlackPearlZ71's Avatar
I just tested my tru trac this past wednesday, I love it!!
Old Jan 4, 2008 | 06:16 PM
adam1803's Avatar
Mine was delivered about 10 minutes ago, can't wait to get my gears and install it.
Old Jan 4, 2008 | 06:22 PM
nick993's Avatar
so down the strip would it give a better launch or traction than the g80?
Old Jan 4, 2008 | 07:10 PM
adam1803's Avatar
definetly
Old Jan 4, 2008 | 10:33 PM
What ratio are you going with? I have 4.56's with my 6 speed and love it,I also installed a tru-trac when I did the gear swap. I had to do some trimming on the tru trac due to the gear thickness.
