True Trac ?
Old 01-05-2008, 01:16 AM
  #21
adam1803's Avatar
Originally Posted by 1969x11
What ratio are you going with? I have 4.56's with my 6 speed and love it,I also installed a tru-trac when I did the gear swap. I had to do some trimming on the tru trac due to the gear thickness.
4.88 ratio
Old 01-05-2008, 01:40 AM
  #22
03chevy5.3rcsb's Avatar
Originally Posted by adam1803
4.88 ratio
Nice!
Old 01-06-2008, 04:20 PM
  #23
TOTM: June 2007
bgray's Avatar
hoockie momma...4.88's..work great with the 6speed tho
Old 01-06-2008, 07:33 PM
  #24
regency's Avatar
what would that compare to in an A4
Old 01-06-2008, 10:39 PM
  #25
adam1803's Avatar
You'd have to plug the numbers into a calculator to say for sure, but probably about like running 4.10's
Old 01-06-2008, 10:49 PM
  #26
formerly 20032wdsilverado (8/29/2011)
how would 4.56s run in a 4l60e and with 35 inch tires?
Old 01-07-2008, 11:34 PM
  #27
regency's Avatar
should i get a TA cover or similar or just leave stock and save that $200
Old 01-08-2008, 05:45 AM
  #28
Moddoo's Avatar
With the true trac, you can punch it with one tire in the dirt and the other tire will still lay rubber.
They work excellent.
No more inside tire spinning and can't accelerate BS.
When you push the throttle you take off hard. left, right, straight, doesn't matter.
Old 01-08-2008, 08:57 AM
  #29
TurboGibbs's Avatar
The heavy duty covers are a must with a manual IMO. The jack bolts that contact the carrier brg caps along with the cover provide support to keep the pinion from seperating from the ring gear under heavy loads like clutch dumps. When the ring and pinion push away from one another they mesh on the outer edge of the teeth and break.
Old 01-08-2008, 09:09 AM
  #30
TurboGibbs's Avatar
I've had 3.73, 4.30 and now 5.13's with my T56.
My opinion on gears with a T56 is if you have tires in the 29-30" range go with 4.88's and tires in the 32" range 5.13's.
With 32" (275/55-20's) tires and 5.13's i'm doing 1900 rpm in 6th at 70mph and first gear launch is perfect.
Quick Reply: True Trac ?
