Truck won't start, have fuel & spark, Need Help!
Old May 17, 2008 | 05:01 PM
Default Truck won't start, have fuel & spark, Need Help!
I have not been able get my truck started. I thought it was the fuel pump, but I checked the pressure. It was 49 psi, which is the same as my wife's Tahoe. So I assume it is okay for now. I checked my spark and looks good there. The thing I am concerned about is what is in my catch can. It looks like chocolate milk, and smells like gas. I have noticed it before, but I have not been driving it since November. Another thought was bad gas. I purged 5 gallons out, but I am not convinced it is bad gas. I also tried throwing some gas in the intake, and nothing happened. I switched batteries and no luck. I am really at a loss. Could it be a bad head gasket? Ground? Fuse? I have a TSP 228R if that helps.
Old May 17, 2008 | 05:05 PM
Mangled03gmc's Avatar
Baltimore Whore
Thats sucks man, looked at my post earlier, my **** box isn't starting either.... I am getting spark, cause it is fire over but only 1-2 times, thats it. Good luck to us both...
John
Old May 17, 2008 | 05:10 PM
I saw your post as well. GL to ya.
Old May 17, 2008 | 05:59 PM
rgvsierra's Avatar
does it backfire when you crank it?
Old May 18, 2008 | 07:21 AM
Nope. I just hear the compression release when the exhaust valve opens. Actually, I found a fuse blown in the under the hood electrical box. It was SEO 1 15A, but I think that is going to solve another problem. It wants to start over now. Struggles, but just won't fire over. I tink it my be a combination of a weak battery and bad gas. ????
Old May 18, 2008 | 07:36 AM
95ImpSS's Avatar
formerly 1BADC10 (12/14/2011)
Originally Posted by sleek silverado
...but I have not been driving it since November.
Assuming you have proper fuel feed (pressure and actual fuel to rails), presence of spark to ALL plugs, and all fuses are in tact, then I'd look to check your injectors to ensure they're functioning properly. Especially since you've not driven the vehicle since November.
For future info, I'd definitely use some type of fuel stabilizer if going to store for extended periods. But, I'm sure you knew that.
Old May 18, 2008 | 04:05 PM
It was my plugs. I changed them and it started right up. I guess the old ones were fouled?
1Bad, I was telling myself all winter long, I need to get some fuel stabilizer. I never did. Luckily it was not the issue.
Old May 19, 2008 | 10:37 AM
I'd start with the Cranksahft Position Sensor first. Then check your Ignition switch/cylinder. We have problems with the Passlock Sensor, located in the cylinder casing, all the time. Ignition switches are known to go bad with these trucks alot. Also, do you have any MILs like the security light on or anything?
Old May 19, 2008 | 11:30 AM
95ImpSS's Avatar
I think he found the problem. Said it started right up after he changed the plugs.
Glad you got it fixed. Now go burn that old fuel out, and put some fresh fuel in.
Old May 19, 2008 | 08:20 PM
I just drove it 450 miles with no issues!
wrb002
Aug 31, 2015 12:00 PM
chevyl33
Aug 24, 2015 08:21 AM
cams 98 silverado
Jul 31, 2015 07:36 AM
InsaneDomestics
Jul 27, 2015 02:42 PM
black6spdz
Jul 16, 2015 01:32 AM
