Truck wont start + bad idle when it does, HELP!
Old Jan 11, 2010 | 06:08 PM
Midnight's Avatar
Default Truck wont start + bad idle when it does, HELP!
Hey guys I wonder if you could help me out on this one.
Over the last couple days my truck has been misfiring and idling crappy. Yesterday it flat out died on me. I figured it was some bad gas maybe so i changed the fuel filter just because. The filter was pretty gummed up so I thought that might solve it. It started up strong after installing the filter, put bottle of heat in it, and thought it was good to go. This morning i started it up and began to drive but it died 10 feet later. It seems to want to die when I hit the throttle, so could this be a bad fuel pump? Any help would be great, thanks.
Old Jan 11, 2010 | 07:25 PM
aksz71's Avatar
mine was doing about the same and i changed filter and it didnt help and it ended up being the my positive battery terminal wasnt tightened all the way. dont know if that'll fix yours but that what my problem was
Old Jan 11, 2010 | 09:25 PM
Midnight's Avatar
Nah I figure its the fuel pump. Truck as 131K on it so I decided to get the wallbro 255 from TSP.
Old Jan 12, 2010 | 01:39 PM
BlownChevySS's Avatar
I couldn't get mine to run when my fp crapped out. Good your getting the Walbro, but check your fuel pressure just in case it's something else. Any codes or CEL?
Old Jan 12, 2010 | 03:53 PM
Midnight's Avatar
Yeah I was getting the two lean codes along both banks.
Old Jan 12, 2010 | 05:16 PM
Fireman31's Avatar
Dirty or bad MAF sensor.....try cleaning the MAF and also clean the TB while you are at it. Also, double check to make sure all of your intake clamps are tight........
Old Jan 13, 2010 | 01:52 AM
Midnight's Avatar
Well now when I go to start the truck I hear no priming sound from the pump. Wallbro on teh way!
Old Jan 13, 2010 | 01:56 AM
viciousknid's Avatar
Where's the Beef?
Fuel pump or intake gasket was my guess.
Friend of mine just had to replace her intake gasket and had similar symptoms.
Old Jan 13, 2010 | 02:55 AM
Midnight's Avatar
wowzow
Old Jan 13, 2010 | 09:04 AM
VasatDiablosport's Avatar
Registered User
^This^
It definitely sounds like you have a vacuum leak. Before you go spending money on replacing parts unnecessarily, check your fuel pressure as previously stated, then check for vacuum leaks and if all seems well, take a look at your maf sensor.
The only reason for you to be getting a lean code on both banks would be a vacuum leak IMO.
