Titan rear window on Silverado
Old Sep 28, 2022 | 08:06 PM
  #141
shakenfake's Avatar
Shlumpt
5 Year Member
@Herke Siempre Tumbado has a kit that you can buy. There is no way that is $30 nowadays lol
Old Mar 2, 2023 | 12:59 AM
  #142
someotherguy's Avatar
Originally Posted by ElntTcare
I know that this post is pretty old, but I am also searching nowadays for a Titan rear window on Silverado. Could someone provide me updated info on where I can order one? Also, is it worth installing some car shades on my windows?
I prefer lace curtains, also lace doilies on the dash and seat covers are very nice. I have a real mink fur steering wheel wrap it is DELUXE and I mean LUXURY DELUXE
Richard
Old Mar 2, 2023 | 09:25 AM
  #143
shakenfake's Avatar
Shlumpt
5 Year Member
@someotherguy You are fancy!
@ElntTcare Just find one in a junkyard
Old Mar 3, 2023 | 12:13 AM
  #144
SIX650's Avatar
Registered User
Default Rear window screw/bolts
Originally Posted by kaze_v8
Did you how those little screws/bolts on the outter edge of your glass??
Just get a Dremel or cutoff wheel and cut them off
Old Mar 13, 2023 | 12:37 PM
  #145
mob1's Avatar
Registered User
Your work is good boss man! Good **** bro. I’m from az too that’s sick. I haven’t seen this yet.
Old Jun 23, 2024 | 05:46 PM
  #146
Dans_nbs_sierra's Avatar
Default Do not buy
Don't buy that pan from SIEMPRETUMBADO it's a waste of 300 bucks. First got it in the mail. Bent to all hell. Super thin metal. None of the tabs matched where it need to be mounted. I tried to bend everything back that I could to make it look decent. Put it in flexed when the window motor moved. Ended up going to the amish and had a 1/8 inch aluminum pan bent to fit.
Old Jun 23, 2024 | 06:42 PM
  #147
terravast4's Avatar
the Amish made you a pan??
Old Jun 24, 2024 | 09:07 AM
  #148
shakenfake's Avatar
Shlumpt
5 Year Member
That is what I was wondering too lol
Old Jun 24, 2024 | 11:18 AM
  #149
strutaeng's Avatar
5 Year Member
All done with only hand tools too!
Old Jun 24, 2024 | 11:33 AM
  #150
IIGW's Avatar
5 Year Member
Originally Posted by retrainh
If you want, I can send you an install kit that includes the molding, primer, urethane, and cleaner required to install the window. I use all DOW Betaseal products.
I can include
2 tubes of u-428 urethane with Precut V-notch tips
1 can of 5504g Primer
1 can of GC800 Glass Cleaner
2x Primer Applicators
4x Single-sided Razorblades
15 ft of the t108 molding (should be 2.5x what you need)
Instructions and tips on how to properly replace the glass (not the inner regulator portion but the actual bond to the vehicle and prep work.)
only thing you’ll need is a good ratio caulking gun, not a cheap one because you’ll never push this urethane by hand with a low ratio geared gun, I use electric guns for work.
Can send it anywhere in the US. $30 plus shipping usps priority flat rate.
Would be nice if these prices were still the same a few years later...
