Titan rear window on Silverado
#131
Do you mind DM' me please!
#134
#135
As of today 3/29/18 I got the rear window removed yesterday and I cut the back panel off the truck. I'll be installing the rest today. I found a shop that has installed them with a new molding so ill be doing that should like like this one here. More pics as it comes along.
#137
#138
If you want, I can send you an install kit that includes the molding, primer, urethane, and cleaner required to install the window. I use all DOW Betaseal products.
I can include
2 tubes of u-428 urethane with Precut V-notch tips
1 can of 5504g Primer
1 can of GC800 Glass Cleaner
2x Primer Applicators
4x Single-sided Razorblades
15 ft of the t108 molding (should be 2.5x what you need)
Instructions and tips on how to properly replace the glass (not the inner regulator portion but the actual bond to the vehicle and prep work.)
only thing you’ll need is a good ratio caulking gun, not a cheap one because you’ll never push this urethane by hand with a low ratio geared gun, I use electric guns for work.
Can send it anywhere in the US. $30 plus shipping usps priority flat rate.
#140
I can include
