Titan rear window on Silverado
#32
The following 2 users liked this post by Guess075:
AGearHead4Life (12-28-2018),
Rayray1958 (05-26-2019)
#33
#34
when I installed mine I cut 2 of them off and used the rest. You can probably use them all. I welded metal tabs to the original lip the silverado window fits in and drilled a hole through the center of them. Sp my glass is bolted as well as glued.
#36
Can anyone do an in depth write up on how to get this all done?
Gaskets, and where to cut and what kind of extra bracketing will be needed?
Im in the process of buying my rear window, and id like to give a crack at it.
Im doing it on an NNBS btw.
#37
I just did the swap. Was way easier then I thought it would be. My only problem now is the wiring, the titan rear window motor has 6 wires coming from it, and I can't find a diagram anywhere for it.
I am curious how everyone else has wired the motor up.
