tire size with drop?
Well I need new tires and I'm about to put 2 inch LCAs and 2 inch hangers on my truck. And it should be overall a 2/5 drop cause I have 3 inch shackles already. I'm just wondering what's the tallest /widdest tire I can fit under it. I have 20s and the tire size is 275/45 right now.
Like 02Bluestepside said... backspacing is key! honestly you should be fine with any size you run. rubbing shouldnt be bad out back up front you still should be fine with just a 2in drop unless your running like 345s hahaha
also... why are you going LCA's??
Unless you have the blitzkreig(sp?) shackles or you cut to fit the 2500 shackles, you don't have 3" shackles. 3" taller shackles does not equate to a 3" drop.
As far as your question, no one can say for sure without knowing what kind of wheels you have, or more importantly their width, offset/backspacing. Not all 20" rims will fit the same. I tuck 30" tall tires with almost a 5/7 drop but that's only because I have perfect backspacing.
FlowmasterMufflers
Jul 30, 2015 05:03 PM
