Tire Pressure ?'s
I run the front about 5lbs more than the rear. I run the rear by the label , The front will wear on the outer edge so the added pressure helps bow the tire out and wear the middle down some.
30PSI all the way around like my sticker says. You won't wear your outer edges of your tires out if you keep up with your alignments and rotations that are recommended.
I'll only add psi if I'm towing or hauling heavy weight. Though I only put 40psi to the rears (if load is heavy) and put 35psi up front.
Rotations: 5-6K
Alignments: 12-15K or whenever the suspension has been changed
My 275/55/20 Goodyear Eagle LS tires have 30K on them. They are just a tad worn past half way of tread life. They have 6/32 of tread life.
Jim
Rotations: 5-6K
Jim
Resident Retard
But thanks for the info thou.
Originally Posted by BlackGMC
i have the same tires and they only have ~20k on them and I am all ready having to buy a set. Honestly, I don't do burn outs or anything crazy......
My tires have been under several burnouts. At the track and the street. All comes down to preventative maintenance in the end.
Rotations and alignments keep your tires lasting the longest.
Just look at mine. I rotate mine every 4,000-4,500 miles. Basically, every oil change.
Jim
well.........heres what I do on the front AND the rear. I take a can of white paint and carefully spray a stripe across the tread on all four tires and let it dry. After it dries I then drive the truck down the street, then I check the wear pattern on the stripe, if there is any stripe left on the outside of the tires I will lower the pressure in the tires just until the whole stripe is worn off, this insures that the contact patch is at its widest. If the stripe is worn off, I will then raise the pressure in the tires and spray another stripe on the tire then do the whole procedure again. IF the contact patch is at its widest this means that the whole of the tread is in contact with the road, this equals the least amount of wear, the least amount of wear equals longer tire life......this works for me.
Originally Posted by Soon2bSpooled
that seems like alot of work to get optimal PSI, i wouldnt have the patience, i would say go with whatever the specs on the tire you buy say
Did I mention that this also maximizes traction..which also maximizes brake effectiveness, the list can go on...?
05GMC4.8
Aug 7, 2015 09:55 PM
GMCtrk
Jul 17, 2015 06:39 PM
