theftlock?
Old Apr 11, 2006 | 05:56 PM
kiserhd's Avatar
Default theftlock?
Just picked up a stock 04 cd player and unfortunatly it was locked. I called the dealership but the service department was closed. Anyone know the going rate for a dealership to unlock the radio? Can it even be done if the radio is not in the truck it was originally installed it? Thanks in advance.
-Kiz
Old Apr 11, 2006 | 06:06 PM
04BlackGmc's Avatar
10 Second Club
this is really weird ill look into it
Old May 17, 2006 | 06:04 PM
z7199's Avatar
ever find anything out on this my buddy has the same probvlem
Old May 17, 2006 | 07:01 PM
Blown02Sierra's Avatar
wait, locked as in you need the code, or locked as in wrong code too many times?
Old May 17, 2006 | 07:06 PM
z7199's Avatar
locked as in need a code I did a search and called the number it says but the dealer code I had or whatever is not right
Old May 17, 2006 | 07:31 PM
yah, u gotta call that number and then enter your vin or something and they give u the code
Old May 17, 2006 | 07:32 PM
z7199's Avatar
do you have that number or anything because I cant seem to get it to work
Old May 17, 2006 | 10:16 PM
03NHSilvy's Avatar
I think 03+ radios are using a different theft lock system, it doesn't matter if you unplug it or anything, but it knows the VIN of the truck its supposed to be in, if you swap it, it locks up and needs to be unlocked. I don't think the phone number will work for these radios, you need the Tech II to get into the BCM
Old May 17, 2006 | 11:12 PM
99Silver6.0's Avatar
Maybe it will or wont work on that unit. But give it a shot!!
01. Turn the ignition ON (The radio displays LOC)
02. Hold down the radio preset buttons 2 and 3 for six seconds
03. The radio display changes from LOC to a three-digit number. Write this number down.
04. Press the AM/FM button
05. The radio display changes to another three-digit number. Write this number to the right of the first one.
06. You now have a six-digit number, the first three digits are from STEP 03 and the last three digits are form STEP 05
07. Call 1-800-537-5140
08. Press 1 then # (pound). You’ll hear “Invalid Code, try again”
09. Press 139010 then # (pound). You will be asked to enter your four or six digit code followed by the * (star)
10. Enter the number from STEP 6 then * (star)
11. Listen to the four-digit number and write it down. It will be repeated twice
12. Turn the ignition ON (The radio displays LOC)
13. Use the MN and HR buttons to enter the code from STEP 11
14. Press the AM/FM button. The radio display changes to SEC Your radio is now “un-locked” and usable. The Theft-Deterrent feature is STILL active! If you want to disable it, use the instruction on page 3-27 in your Y2K Owner’s manual. Use the code from STEP 11 instead of your personal code.
Old May 18, 2006 | 07:10 AM
z7199's Avatar
Thanks it worked!
camcamaro1991
Jan 31, 2024 12:43 AM
ZZebes
Jun 2, 2008 02:13 AM
2000 SILVERADO
May 16, 2005 07:06 PM
