Temp gauge inop
Old Jun 19, 2010 | 06:03 PM
1Bear's Avatar
Any time Tim, you know I'm always glad to share pictures I got mine from JPCustoms, but I know that you can find them cheaper. The 99's are wierd and something happens where you get an airbag light or something like that when you install one of the different clusters with the temp gauge/120mph speedo, and the one from JPCustoms is already modified to fix that, so I took the easy, but more expensive route.
It's been so long since I've seen a stock C3/Denali instrument cluster and not an Escalade or aftermarket unit, that it's actually refreshing. JPCustoms had a lot of cool stuff, they were fairly expensive, but put together some otherwise sometimes hard to locate parts. Also, as you mentioned the '99 & '00 models will illuminate an a light when a cluster from an '01 / '02 is installed. I actually thought it was the alternator light, but whatever. JPCustoms modified the units in whatever way was necessary to make them truly plug & play, but unfortunately they have since went out of business. My steering wheel came from them.
Old Jun 20, 2010 | 07:31 AM
fastnblu's Avatar
Finally got my truck back on the road today, popped the updated BlackBear PCM in, installed the new relays into my fan harness,... Everything was great, hooked up a scan tool to see how everything was doing, LTFT's were close to zero, everything was working as it should, ... when suddenly the temp gauge dropped from 185ish to 160 and stayed there. I pulled over and took a quick look at the temp sensor in the head, it was plugged in and the wires look good, so my gut says that the stepper motor took a crap. What sucks is that this is a Denali cluster, and it doesn't even have a ton of miles on it...
anyway, enough BS-ing...when I get a chance I'll test the wiring (I'm sure that there's a test that I can do where I ground one of the wires or jump them out of something...unfortunately I'm packing since I'm moving and I already packed my service manuals), and the sensor probably has a resistance test that I can do...but, if it is a stepper motor, where's the best place to get one?
X25.168 updated stepper motors are what I believe you're lookin for. I'll call ya about this.
Old Jun 20, 2010 | 08:31 AM
budhayes3's Avatar
PT's Slowest Truck
Thanks bro...it's still working lol...maybe the PCM was still learning or something...
Old Jun 20, 2010 | 11:02 AM
brent5631's Avatar
Yeah I love my stock denali cluster. got it on ebay already fixed for the light problem.
Old Jun 21, 2010 | 07:06 PM
budhayes3's Avatar
PT's Slowest Truck
Don't know how I missed your post Jarrod, nice looking wheel...I had no idea that JPCustoms went under....
Plug and play is great huh Brent
SS94S10
Jan 3, 2019 01:57 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
JordanH
Oct 3, 2015 03:59 PM
zblee
Sep 17, 2015 07:58 AM
kmcn47
Sep 17, 2015 01:12 AM
