Successfully tuned 102/102 FAST intake tune file?
#31
these lsxrt 102 intakes are known to be warped...known to leak...known to flex/inflate with vacuum/boost....and probably the only intake on the market I would never consider running.
FAST did a complete swing and miss with this intake. when it seals, it runs great at WOT. 99.999% of the time, our street trucks are not at WOT.
#32
#33
None of fasts other intakes have this much negative feedback...and they have seemingly done nothing to help with the situation. In fact they usually tell whomever it is that speaks to them that its the first theyve heard of it. When its obviously not.
#34
For those having tuning issues with the LSXRT, are all of you running 102 mm TB's cause I'm betting thats the problem right there. The larger 102 TB's are just a bitch to tune although the cable style TB's are alot easier than the DBW electronic units.
I have ported numerous truck intakes for folks and never had an issue with the ones I sent out although ultimately that rests on the capabilities of the tuner.
Just curious if the guys experincing the issues are using 102 TB's and whether they are cable or DBW style
Cheers,
Tony
Cheers,
Tony
#35
Cheers,
Tony
Cheers,
Tony
But my issue was definitely vacuum leak. And almost everyone that ive read about had problems with warped intakes/improper sealing aka vacuum leaks.
Not tuning issues...but im sure that has been the issue for a few people.
V-seriesTech
Jul 28, 2015 12:31 PM
