Stupid Little Brother
Old Aug 2, 2007 | 10:31 PM
Puddin's Avatar
Default Stupid Little Brother
My idiot brother ran his truck out of gas.
Its 5.3 2001 reg cab chevy
Now it will not start. Someone my dad knows told
them the fuel pump burnt up.
Before we replace it anyone have any other suggestions?!
Old Aug 2, 2007 | 10:34 PM
ReSpAwN DeMoN's Avatar
Don't mean to be a smart *** here but..
did you fill it back up with gas?
Old Aug 2, 2007 | 10:46 PM
thunder550's Avatar
High on diesel fumes
It's possible that the pump burnt up. When you turn the key to run, do you hear the fuel pump come on to prime for 1-2 seconds?
Old Aug 3, 2007 | 12:59 AM
Ferocity02's Avatar
Yeah, it's probably the pump. I don't think gasoline engines need the fuel lines to be bled of air after running out of fuel.
Old Aug 3, 2007 | 08:05 AM
Puddin's Avatar
Yes we put gas in it. I knew I should have put that in there
at the begining. We towed it to my dads house last night. but havent
worked on it yet.
I will check to see if I can hear the pump coming on.
THANKS
Old Aug 3, 2007 | 08:58 AM
Nick™'s Avatar
if the pump is working you may want to replace the fuel filter (even if it's not still do it), you you suck down to the last bit of gas often you'll pick up all the fine particles in the tank and clog the filter.
Old Aug 3, 2007 | 10:19 AM
beastmode's Avatar
Import Moderator
Old Aug 3, 2007 | 10:53 AM
ZR1 DREAMING's Avatar
Damn... that's funny.
+1 for a burned out pump.
Old Aug 3, 2007 | 10:56 AM
Yogi Bear's Avatar
Have you checked the fuel pressure yet? I'd do that first before tearing into the tank and pump. Pumps are expensive and a PITA to replace!
Old Aug 3, 2007 | 11:22 AM
2001si3rr@'s Avatar
+1 for checking the pressure. Replace the fuel filter then check the pressure on the fuel rail.
