stock shortblock may be hurt/gone :( ( serious issues )
Old Dec 12, 2010 | 09:31 PM
skeet's Avatar
Originally Posted by bluecajun5.3
my friends ls2 was making the same noise as yours. turned out that it spun the #5 rod bearing.
thats very well possible bill, but with a spun rod bearing i would have found some type of metallic material in the oil and wouldnt the noise continue through the rpms and just not at idle ?
Old Dec 13, 2010 | 06:19 AM
mhotrodscooter's Avatar
It doesnt sound like this?
http://www.youtube.com/watch?v=kxbYh...e_gdata_player
Old Dec 13, 2010 | 10:04 AM
dlt76028's Avatar
^^^that sounds like the converter bolts.
Old Dec 13, 2010 | 10:18 AM
skeet's Avatar
im just gonna go ahead and order another UD pulley probably, i could go stock but im gonna need one for the 408 anyway so i might as well get it now.
so for which one would be a better choice?
ATI
Pwerbond/SLP
ASP
who ?
Old Dec 13, 2010 | 12:22 PM
silver-mod-o's Avatar
Hunt&Fisherator
I believe the ATI is SFI approved
Old Dec 13, 2010 | 01:53 PM
midnight_bowtie's Avatar
Originally Posted by mhotrodscooter
Yup sounds just the way mine did.
David, sucks to hear bout your mishap. Hopefully you can get her up and running soon. GL. fyi i can save you a ton of trouble and gas if you wish to light her up. Just let me know so i can give my garage a little cleaning
Old Dec 13, 2010 | 02:05 PM
Actually a cracked flywheel. Noise would go away with a little throttle. But anyway.. Just trying to help.
Old Dec 24, 2010 | 08:23 PM
CashDudeHomie's Avatar
A cable TB sticking at WOT? Is the spring on it damaged? Or is the gas pedal catching on the carpet or something?
You sure you didn't over rev it and bend some pushrods?
Old Dec 24, 2010 | 08:41 PM
skeet's Avatar
loan me the money i looked at ATI
cant explain but it does and its not the cable, but the crank pulley solved the wide open throttle shutting down issue ..it must have something to do with the TPS and rpms since the slp crank pulley failed.
now for update, well i pulled the motor anticipating what the hell i was gonna find, after having the motor out and on a stand, started taking things part, i needed to turn the crank so i grabbed the TCI flex plate, well guess what? all 6 bolts were loose, the flex plate would move back and forth and i was like ***** fugging damn blah blah blah lol.. so i decided to check further into the motor, pulled rear main cap and checked bearing, looked really good, pulled another and also a rod cap all looked perfect. soooo since the motor is out, i'll have it studded with ARP rod bolts in the lower assembly..i would go as far as reringing it BUT why? theres hardly any miles on it ( less 5700 ) so i'll stud it and oil it and wrap it and put it on the shelf for a rainy day
so the 2 issues were the slp pulley and the damn bolts that hold the flexplate on to the crank wtf!!!
Old Dec 24, 2010 | 08:50 PM
1Bear's Avatar
The bolts backing out in regards to a TCI flexplate was a pretty common occurrence due to the coating on the flexplate itself. Most people recommended removing the coating where the bolts contacted the flexplate.
