starter wiring
Old Apr 19, 2017 | 06:38 PM
40series's Avatar
Default starter wiring
my truck was getting hard to start so i installled a new starter, starts grerat for 2 days untill today it was hard to start again,,, i heard this could be a bad or loose wire
Old Apr 20, 2017 | 10:51 AM
06murder's Avatar
sounds like a fueling problom to me,man. what kind condiction the fuel pump is in ?
Old Apr 25, 2017 | 08:02 PM
40series's Avatar
Default i dont know its the original fuel pump
Old Apr 25, 2017 | 08:03 PM
40series's Avatar
how do i check the stater wire my cuz told me its probably a loose wire?
Old Apr 26, 2017 | 07:27 AM
Atomic's Avatar
I have a gauge for that
...see if its loose...
Old Apr 28, 2017 | 01:55 PM
terravast4's Avatar
Old Apr 29, 2017 | 02:39 AM
06murder's Avatar
Something is telling me out it the fuel pump. If you havent touch the starter, I wouldn't worry bout it yet, check fuel pressure.
Old Apr 29, 2017 | 01:43 PM
MikeGyver's Avatar
What does hard to start mean? Does it crank slowly, or does it crank at a normal speed and crank and crank and crank before it finally starts?
Old Apr 29, 2017 | 11:42 PM
psycho1's Avatar
Try to turn key to on position for about 15sec then turn off then try to start if it starts right up after u primed the system u have a fuel problem and not a starter problem. If you can get your hands on a fuel pressure tester would be a good place to start if you just changed the starter.
Old May 25, 2017 | 09:34 AM
40series's Avatar
found the problem it was a ignition wire rubbed through by a bracket which was shorting the line out the guy taped it fixed 240? ouch. i checked his work it was under the steering column
