starter wiring
my truck was getting hard to start so i installled a new starter, starts grerat for 2 days untill today it was hard to start again,,, i heard this could be a bad or loose wire
sounds like a fueling problom to me,man. what kind condiction the fuel pump is in ?
i dont know its the original fuel pump
Originally Posted by 06murder
(Post 5406825)
how do i check the stater wire my cuz told me its probably a loose wire?
...see if its loose...
:dewey:
Originally Posted by Atomic
(Post 5407360)
Something is telling me out it the fuel pump. If you havent touch the starter, I wouldn't worry bout it yet, check fuel pressure.
Originally Posted by 40series
(Post 5406745)
Try to turn key to on position for about 15sec then turn off then try to start if it starts right up after u primed the system u have a fuel problem and not a starter problem. If you can get your hands on a fuel pressure tester would be a good place to start if you just changed the starter.
found the problem it was a ignition wire rubbed through by a bracket which was shorting the line out the guy taped it fixed 240? ouch. i checked his work it was under the steering column
