Is the starter fast enough to build oil pressure?
Old Sep 10, 2012 | 04:37 PM
Default Is the starter fast enough to build oil pressure?
I am putting a lq4/4l80e in a buddies 85 suburban and I thought for ***** and giggles I would prime it before we cranked it. I have never done this before, I always just put oil in them and crank them. Will the starter turn it over fast enough to build any pressure? I have turned it over for about 2 minutes and nothing has made it to the valve cover yet.
I did put on a new o-ring on the pickup but I was carefull and used some oil to lube it so I am pretty confident that I am good there and I have not had the pump off or the rear cover.
Thoughts??
Old Sep 10, 2012 | 04:39 PM
TXsilverado's Avatar
i dont think so. i always just pour oil in directly on top of the lifters/pushrods/rockers and fire it off and cross my fingers
Old Sep 10, 2012 | 04:45 PM
That is what I have always done as well and I have been fooling with these motors for years but I just thought I would try it this time.
Old Sep 10, 2012 | 04:46 PM
Ferocity02's Avatar
If your concerned about it you could pour oil down the oil pressure sensor hole to fill the galleys. Also can load the oil filter with oil. I'm not sure if the oil will bleed into the pan though before you got it back together and started.
Old Sep 12, 2012 | 02:24 PM
Mtrhd329's Avatar
I got mine to prime by pulling the plugs and spinning it over. With the plugs in i would not get any pressure to build. Once the plugs were out it spun crazy fast and primed right up.
Old Sep 12, 2012 | 02:37 PM
TXSZ66AVLANCHE's Avatar
Just start it up, it will he ok. I've done this with all by builds.
Old Sep 12, 2012 | 02:50 PM
Mangled03gmc's Avatar
Baltimore Whore
All of these are true. Done one or the other at one time or another lOL
Old Sep 12, 2012 | 02:56 PM
oakley6575's Avatar
I turned my motor over with the starter until it built pressure no problem. Plugs were in, coils unplugged, and fuel pump relay out of the truck. Took about three cranks and then I saw pressure.
Old Sep 14, 2012 | 10:23 AM
This one would not build pressure with the starter. I even pumped oil through the motor and turned it over and it would not build pressure. I just fired it up with vats still on and after about 3 cranks it had pressure.
superchomper2003
Aug 26, 2015 09:39 AM
USMCvet0311
Aug 14, 2015 10:28 PM
05GMC4.8
Aug 7, 2015 09:55 PM
Ferocity02
Jul 17, 2015 07:05 PM
rojeho
Jul 12, 2015 06:10 PM
