compression test results, can't find info on what it should be
Old Sep 14, 2012 | 04:00 PM
TXjeepTJ's Avatar
Default compression test results, can't find info on what it should be
Been having a problem with the engine idling very rough when it is fully warmed up. It is also not as fast as it should be. I've been getting a lot of blow by and the crank case has been getting pressurized when I go into boost.
I checked the compression, these are the results from the drivers side. This is the max value I got after 3 compressions
1: 125 psi
3: 100 psi
5: 100 psi
7: 120 psi
I added oil to cylinder 3 and on the 3rd compression it reached about 160 psi. So I am to suspect most of my rings are done. Cylinder 3 and 5 also had oil on the spark plug.
Do all these numbers seem very bad?
I tested these cylinders when the engine was fully warmed up.
Old Sep 14, 2012 | 04:05 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
That's too low. 170-200 is what you want, depending on the setup.
Time for a teardown.
Old Sep 14, 2012 | 04:08 PM
TXjeepTJ's Avatar
170-200.. yup! It's done! haha thanks man.. I'm glad I found my problem
GXPJAY
Feb 13, 2022 08:15 AM
GrooveCityZ71
Aug 31, 2015 12:05 PM
05GMC4.8
Aug 7, 2015 09:55 PM
gtyler04
Jul 28, 2015 06:21 PM
