Silverado Overheating
Old May 30, 2011 | 04:27 PM
kostelacd69's Avatar
Default Silverado Overheating
Fixed
Old May 30, 2011 | 05:09 PM
joeyc125's Avatar
11 Second Truck Club
mine did the same thing when I lived down in tempe. Electric fans seemed to cure it for me. I think maybe the stock clutch fan can't pull enough air at idle to cool the condenser and the radiator? You could also try a 34" radiator from an 05+ or 2500 truck, they bolt right in.
Old May 30, 2011 | 05:40 PM
Yeah ive been thinking about that for awhile. the problem is my intercooler wraps around the tanks of the rad. which means i would have to redo my intercooler AGAIN lol. Also i have tried the eletric fan kit from flex a lite for the 28 inch rad. it seem to work at idle but when pulling a trailer at night doing 70 i could not control my temp. it just kept climbing. what did you do for a rad and fans?
Old May 30, 2011 | 06:25 PM
Beatdown Z's Avatar
Laid Back
You're not running a grille insert that would reduce airflow, right?
You could try advancing the timing at idle. From my experience, it helps the old SBC's...
Old May 30, 2011 | 06:36 PM
454navyss's Avatar
160* t-stat, 34" radiator, 05+ electric fans....problem solved
or just take the a/c off of it
Old May 30, 2011 | 07:50 PM
no nothing is in the way. It did it stock too. Cant just change rad with out changing a bunch of other ****. just thought maybe someone had made the 28 inch work.
Old May 30, 2011 | 07:51 PM
Take the A/C off?????? Hmmmmm no. I live in Phx, its kinda hot some times.
Old May 30, 2011 | 07:52 PM
just reviewed a tune, the timing is set to idle around 25-32 degrees
Old May 31, 2011 | 10:42 AM
Coban's Avatar
This is not true, all your old hoses and transmission cooler lines will fit right up. I have done this personally. Its a little clever engineering on GM's part.
Old May 31, 2011 | 12:03 PM
joeyc125's Avatar
His intercooler piping wraps around the 28" radiator, it won't fit with the 34" Are your turbo pipes wrapped well, turbo blanket? Anything you can do to keep the heat out from under the hood will help it.
