sheared off bed bolt removal
Old Mar 6, 2016 | 09:35 AM
40series's Avatar
Default sheared off bed bolt removal
some body man must have over tightened one of my cab to fram bolts ... now im trying to get the cab up to change the fuel pump ,,,,,
*can i simply take the other 5 out to get it off
* the head cap off the bolt is broken off and the stud is threaded in the hole
i need this out to get the bed off
any ideas????????????
Old Mar 6, 2016 | 10:19 AM
skolman91's Avatar
If the head of the bolt is off its free, the bolt threads into the bed so now the stud is just going to be stuck in the bed. Putting it back on will be a little more tricky now but not impossible as its just getting that stud back in the hole and tightening the others (there are 4 on each side 8 total iirc)
Last time i had to take my bed off i was without air tools and managed to get one hung up and had to cut the head off, im sure this is a common occurrence in the north..
Old Mar 6, 2016 | 11:22 AM
Wolftrk99's Avatar
Once beds off you may actually be able to cut the speed nut and get the bolt out, and get a new speed nut and bolt and be good to go....
Old Mar 6, 2016 | 06:16 PM
40series's Avatar
Default doing the tilt bed method
im takiing 4 of the bolts out one side and loosening the 9 well 3 on the other side to lift and support the one side... i broke all 7 free today to make sure there wont be a problem
Old Mar 6, 2016 | 08:02 PM
2002_Z28_Six_Speed's Avatar
I'd use CRC Freeze Off or PB Blaster on the remaining bolts and let it sit so you don't create additional work for yourself.
Old Mar 6, 2016 | 09:34 PM
Wolftrk99's Avatar
I usually just pull all the bed bolts and set it on the tire and bumper with the support braces centered on each of them
Old Mar 12, 2016 | 08:05 PM
2K Silvy's Avatar
Funny this just happened to me. I hate Michigan.
I did one side and the results were the following...
One bolt came out perfect. One bolt sheered. One bolt is spun. Now I gotta grind it off. I stopped and went inside after that. It's not like you can access the freaking nut so now I got to grind everything and waste hours of time.
Scain33
Feb 17, 2016 09:15 AM
Jonblarc7
Feb 16, 2016 08:27 PM
ALL ULL C
Feb 16, 2016 09:51 AM
Garrett Scott
Feb 14, 2016 03:22 PM
