S-10, need help.
Old Jan 18, 2007 | 10:28 PM
D King's Avatar
Default S-10, need help.
Having problems, I got a 96 S-10, just the gettin around vehicle, and the lights will begin to flicker at night, going between daytime driving lights and the low or high beams. I also have to unplug the winshield wipers so that they will go off, otherwise the delay just stays on. Any suggestions?
Old Jan 18, 2007 | 11:35 PM
negativeswitches's Avatar
sounds like you have one of the gremilin trucks
the 94-early 8=98's are known for thier electrical problems
try www.s-seriesforum.com
it sounds like you have a coupple loose connectors somehwere tho.
if it's been wrecked acommon problem is loose screws under the fuse box under the hood
-Erik
Old Jan 19, 2007 | 06:26 AM
Grumpy5.3's Avatar
your wiper problem is that you need a circuit bord that goes inside the wiper motor housing undr the hood... you lights sounds like a loose ground
Old Jan 21, 2007 | 04:19 PM
D King's Avatar
I put a new circuit board in it and still had the same problem.
Angry Silverado
Oct 21, 2015 07:07 PM
Wrecker 426
Sep 30, 2015 09:39 PM
LARRY01Z28
28
Sep 28, 2015 07:54 AM
kalikid06
Sep 13, 2015 05:48 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
