Is it rod knock, piston slap or flex plate rattle???
Old Jan 21, 2012 | 01:45 PM
shtnfrds's Avatar
Default Is it rod knock, piston slap or flex plate rattle???
I have a noise that I don't really know how to narrow down.
Engine-
2001 5.3 with 125K miles. Absolutly stock.
Problem-
While stopped, trans in D, I can raise and hold the RPM's to 900-1000 and hear a constant steady rattle/knock. It also does it if ideling thru a parkinglot and I give just a liiiittle bit of gas.
During a cold start it knocks like hell, but goes away for the most part after a few minutes. I'm thinking piston slap there. Pretty sure I'm confident in that.
BUT, the other noise? WTF is it? I tried capturing it on video, but too much background noise/distortion to hear anything pertaining to the noise.
I've heard the flexplate, or maybe it was the TC bolts, can work loose? Could they make this sort of noise?
ALL help is appreciated. Thanks.
Old Jan 21, 2012 | 04:47 PM
Slammed96's Avatar
I would hop under it and just double check the TC bolts, that way you can at least narrow down the possible causes.
Old Jan 21, 2012 | 05:57 PM
726.0chevelle's Avatar
13 Second Truck Club
Check the torque converter bolts for sure first. Mine tapped at idle and lite throttle and it was just one bolt loose
Old Jan 21, 2012 | 09:15 PM
shtnfrds's Avatar
Can I get to the TC bolts thru the larger round silver plug/plate thing? Looks like it may be an access port??
Old Jan 22, 2012 | 11:38 AM
Slammed96's Avatar
Yep, thats exactly what its for.
Old Jan 22, 2012 | 12:06 PM
skinny chicken's Avatar
I had the same problem it was the cats. Sounded like a rod knock. Crank it and beat on the cats with a hammer a little and see if it changes.
Old Jan 22, 2012 | 12:17 PM
stroker87's Avatar
+1
if you hit the cat and here it rattle thats what it is, had this happen to me
Old Jan 22, 2012 | 01:10 PM
shtnfrds's Avatar
AHH! I didn't even think of the cats. Had that on my old 93 Z28 i had, the sheild seams busted loose and rattled like hell.
Thanks, I'll be under the truck looking for this fix as soon as I get the drivers door hinges pins/bushings done.
flatblack83
Jan 3, 2026 07:10 PM
lucas287
31
Jan 12, 2021 06:18 AM
Alco
Sep 4, 2015 04:08 PM
hackrst
Sep 2, 2015 05:27 PM
