Road trip with lifted Tahoe: pre-trip inspection??
Old Nov 9, 2010 | 06:05 PM
coldkillinTA's Avatar
Default Road trip with lifted Tahoe: pre-trip inspection??
My wife and I are traveling to Colorado Springs (15-16 hrs) for Thanksgiving and we decided to take the tahoe for safety reasons in case it snows/storms (4wd,35",etc.). I was wondering what to check and/or change before the trip(fluids, etc.)? It's a 2004 with 75k miles, 4WD, etc. I was most likely going to change the trans fluid anyways but I would like to hear opinions/comments from y'all. Any help is appreciated!
Thanks
Clayton
Old Nov 9, 2010 | 06:45 PM
dlt76028's Avatar
change the oil and don't forget a spare. And alot of gas money....
Old Nov 9, 2010 | 06:51 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I wouldnt mess with the trans fluid, seems it causes more problems than anything.
Old Nov 9, 2010 | 07:10 PM
mhotrodscooter's Avatar
Carry a extra belt, some tire plugs & a 12 volt air pump.. & a little bag of tools..
Old Nov 9, 2010 | 07:45 PM
I'm curious as to why you said don't change the trans fluid. What problems does it cause?
Also, what about trans case fluid, differential fluid,etc.???
Change or leave it alone?
I appreciate all the suggestions!
Old Nov 9, 2010 | 09:31 PM
Mud slinger's Avatar
Just check all your fluid levels and if they look good and the fluid looks good, roll with it.
Old Nov 9, 2010 | 10:17 PM
1slow01Z71's Avatar
Seems when people flush a transmissino that has previously been great it blows up shortly after. Purely speculation but the general consensus is that flushing the trans knocks loose debris in the trans clogs up the valvebody.
Wouldnt be worried about the diffs but wouldnt be a bad idea to check em, the tcase would be good to check to make sure there arent aluminum shavings in the fluid. A lot of people have had the pump rub problem which requires taking the case all the way apart ot fix.
Old Nov 9, 2010 | 10:54 PM
ap2002's Avatar
X2, i would not change your tranny oil, just top it off if need be... do a fresh engine oil change and roll with it.
BCraven1018
Nov 2, 2015 07:18 AM
gaps
Oct 15, 2015 02:53 PM
11MPG
Sep 10, 2015 08:34 PM
97aztecgt
Sep 10, 2015 05:07 PM
the owl
Sep 4, 2015 04:09 PM
