Replacing The Stock Fuel Pump
Old Dec 1, 2005 | 12:54 PM
URLIFEWASOC's Avatar
Default Replacing The Stock Fuel Pump
Iam having problems with my fuel pump i think but any ways i have like 70k miles on my truck and its an 02 4.8L. does any one know of an aftermarket fuel pump that would be a better up grade than the stock? what are the cons vs the pros to an aftermarket fuel pump. I already replaced the outer fuel filter. the problem i am having right now with my truck is the fuel gauge fluctuates when i am stoped. if some one can tell me the name and place to get an aftermarket fuel pump it would help me out alot thanks david
Old Dec 2, 2005 | 02:23 PM
1SlowHoe's Avatar
Destroyer of Transmissions
I cant remember for sure but I thought that problem was because of a sensor not the pump itself. Do a search on the subject. I think others have had this happen and have fixed it. If you do replace the pump I don't know what pump would be best, depends on your set-up.
Old Dec 2, 2005 | 02:25 PM
ranwalk's Avatar
You just need the fuel level sender. They are now available separate from the pump.
Old Dec 2, 2005 | 07:11 PM
TarheelZ's Avatar
Or you can just ignore the gauge and use the odometer instead.
Old Dec 2, 2005 | 07:20 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
Your sending unit is bad. Esy fix just pull the bed off and pull the whole assembly out of the tank ans swap out the part that has the float on it. Took me and four buddies about an hour to pull the bed swap and put it back on.
Old Dec 2, 2005 | 07:31 PM
SSlow 4.8's Avatar
lol i love how your "easy fix" involves... just pulling the bed off, lol.
im just messin with ya... but wouldnt it be easier to drop the tank one day when u have just a few gals in there?
Old Dec 2, 2005 | 07:50 PM
1slow01Z71's Avatar
Its not hard at all man. If oyu can do it in an hour then its easy IMO. Take the 6 or 8(cant remember) out of the bed, unplug the taillights from the wioring harness near the license plate so you dont ahve to take the taillights out and unplug all the bulbs, disconnect the filler neck and bam the bed is off. Then you can pull all the stuuf out of the tank. Then reverse the process.
Old Dec 6, 2005 | 07:50 PM
HAHAH IM ALRIGHT THERE MY BROTHER WORKS FOR CHEVY IN IRVINE!! I think ill just give it to him since i get everthing below wholesale. but thanks for everything!!!
Old Dec 17, 2005 | 09:33 AM
LS1TRUCKGUY's Avatar
Default fuel pump
speakin of fuel pumps, mine went out last night. new ones from the dealership ar like 400 bucks! anyone know where to get a cheaper one?
Old Dec 22, 2005 | 07:36 PM
clayp's Avatar
ebay they go for $130 for combo pump and sender
5.3Okasai
Mar 9, 2022 01:07 PM
InsaneDomestics
Jul 27, 2015 02:42 PM
lxcoupe
Jul 21, 2015 02:12 AM
76k10chase
Jul 17, 2015 01:48 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
