Question about message "Service 4WD"
Old Jan 25, 2006 | 01:57 PM
  #21
TravisH's Avatar
I got the same light about a month after I got my truck. I just replaced the switch and it has never showed up again.
Old Jun 6, 2010 | 03:13 PM
  #22
2000 Suburban's Avatar
Registered User
Default Thanks for this tip
Originally Posted by rumblebox
take your 4WD switch out. take it apart. grab a solder gun and some solder. re-solder each spot inside the switch. reinstall switch. never have a problem again.
My 4WD switch in my truck only worked on 2HI and 4HI, 4LOW, Auto4WD and Neutral did not work or light up. I read this tip this afternoon, went out to my 2000 Suburban and took my 4WD switch out of my dash and used a couple straight screw drivers to pop the tabs to take apart the switch to get to the circuit board. I noticed right away there was 6 pins that the solder was cracked around them. Also noticed that the solder on all the pins is very thin, so I re-solder all of them with extra solder put it back together, reinstalled it in the truck and now everything works. Auto 4WD, 2HI, 4HI, 4LOW, Neutral.
Thanks very much Rumblebox for this tip, saved me a few dollars not having to go out and buy a new switch.
bk_cauley
40
Aug 17, 2018 05:45 PM
94f150
Oct 25, 2015 06:14 AM
JCW
Sep 22, 2015 03:59 PM
713truck
Aug 18, 2015 09:32 PM
USMCvet0311
Aug 1, 2015 07:45 AM
