Please help.. Why does my TB look like it caught fire?
Old Jan 22, 2005 | 06:23 PM
greentahoe's Avatar
Thanks guys
Old Jan 22, 2005 | 06:24 PM
desTRUCKtive's Avatar
Originally Posted by 04BlackGmc
lmao looks like yes but Oring not gasket,
what does lmao mean, Just for my dum *** future reference. BTW i did not understand your reply.
Old Jan 22, 2005 | 06:26 PM
04BlackGmc's Avatar
10 Second Club
Laughing my *** off...
i ment yes look like yes the forst fire **** is from the EGR.
ktmrider's Avatar
Originally Posted by greentahoe
The gasket on mine stayed in place on the manifold and looked good so I left it. It took me quite some time to get it clean. I used soapy water and a toothbush, scrubber, and even a flathead screwdriver!!! Im just now going to get started on the porting. Wish me luck!!
I still cant believe how bad it looked behind the blade. It was unbelievable!
Use the "seafoam" products to remove the buildup, they work very well. Would not recommend the screwdriver trick tho! But then, you gotta do what you gotta do.
Old Jan 22, 2005 | 06:33 PM
AHHH is see said the blind man, sorry trying to get all this computer language strait. Thanx
Old Jan 22, 2005 | 07:41 PM
sleepersilverado's Avatar
Originally Posted by 900Z1
EGR makes it dirty. I've cleaned mine 4 times in a year.
I will delete it when my HPTuner arrives.
that is funny you say that..... i never knew what actualy caused the build up but i have never had it. that makes since though because i have not hade an egr for ever.
Old Jan 23, 2005 | 01:04 PM
koochingchang's Avatar
how do i clean my tb?? i have used seafoam but i poured it through my brake booster line..
Old Jan 23, 2005 | 01:10 PM
KeukaZ71's Avatar
usually a toothbrush and carb cleaner works fine. then a clean clothe. hard to get behind the blade unless you remove the entire TB. if your gas pedal sticks every so often, then you can get by just by cleaning the TB w/o removing it
Old Jan 23, 2005 | 05:09 PM
dragonman0325's Avatar
Does anyone have pics on what it should look like after it's ported? Sounds like a mod I might be interested in doing.
Old Jan 23, 2005 | 05:23 PM
GREGGO's Avatar
Stock:
Ported:
00loudchevy
Dec 3, 2015 05:54 PM
SSpeeDEMONSS
Oct 3, 2015 08:21 PM
Velocity1
Oct 2, 2015 08:01 AM
Velocity1
Sep 22, 2015 01:32 PM
Glenn98ZM6
Sep 18, 2015 07:31 PM
