Pleasant surprise.
Old Apr 10, 2009 | 07:33 PM
ThrottleHappy7's Avatar
Default Pleasant surprise.
So I didn't have much to do today and decided to change my oil, and thought that while I was under there I'd go ahead and do the trans. fluid as well. Had a lot of fun making a mess in the campus parking lot, but anyway... I decided to try something different. I put my usual can of Restore in with the oil, but I changed up the oil and decided to spring for some Royal Purple. I also decided to tryout some B&M Trick Shift ATF and added some Lucas trans. additive to it. Fired my truck up and could instantly tell a difference. After everything cycled through I started on my drive to work and...
OH MY GOODNESS!!!
My truck has not run like this... ever. I had a big grin on my face all the way to work. I could barely feel it shifting, it was that smooth, and this is all with the original motor and trans. with about 214,000 miles on it. I think I finally found a good combo for my truck. Just thought I'd share.
Old Apr 10, 2009 | 07:34 PM
GMCtrk's Avatar
I absolutely despite soft shifts. I like quick snappy shifts that you can feel in the seat.
Old Apr 10, 2009 | 07:58 PM
As do I... but my truck has been shifting really rough, not firm, and has struggled a bit. So this is a massive improvement. Now, I have yet to take it out and stab it and see how it shifts... I'll probably find out after work.
Old Apr 10, 2009 | 08:17 PM
ChevyTruck's Avatar
something else
Royal Purpal FTW! It's amazing how much better things run with just a fluid change.
Old Apr 10, 2009 | 08:44 PM
viciousknid's Avatar
Where's the Beef?
How many times have you flushed your fluid?
If this is the first time. You better get another one lined up.
If you do it on a regular basis that's cool. I should probably throw some royal in mine next time.
Old Apr 10, 2009 | 09:14 PM
JaymzSS's Avatar
I've been using RP for years.. and don't plan on changing
Old Apr 10, 2009 | 09:35 PM
ChevyTruck's Avatar
something else
Little on the pricey side, but if it helps then its worth it.
Old Apr 10, 2009 | 09:36 PM
Don't know how many times it was done before I got it. This is the second time I've done the trans, as far as I can recall. The last one wasn't too long ago.
Old Apr 10, 2009 | 09:41 PM
Yeah. That's actually the reason why I haven't used it before, but I finally decided to spring for it.
I'm driving three hours home tomorrow, so we'll see how well it does.
Old Apr 10, 2009 | 10:41 PM
00Silv4.8's Avatar
hmm.. thats some stuff to think about. Hope its not just clearing all that gunk out and ur trans is about to call it a day :crossfingers:
A buddy from school put some Lucas trans stuff in his GTI to clean it out and his clutch started slipping, haha the gunk was keeping it together
