p1516
Old Jul 10, 2008 | 04:29 PM
03rado5.3ls's Avatar
Default p1516
ok i have been having a code on my truck p1516 throttle position actuator can anyone tell me where it is located on my truck
Old Jul 10, 2008 | 04:49 PM
oldred95's Avatar
That would be the throttle body. Check the yellow wire which is the signal wire for a break. Should be within about 4-5 inches of the connector if the wire is broken. If it is broken you will see a light colored spot in the insulation and if you bend the white that spot will pretty much turn white and maybe just break right open. There is a bulletin about it out on the 05s and it seems like it applied to the older ones as well.
Old Jul 10, 2008 | 08:06 PM
thanks man
Old Jul 13, 2008 | 12:28 PM
well I put my new computer in yesterday and this morning I was on the way to work as soon as I set my cruise control my truck went about a mile and then it did the reduce engine power crap again
Old Jul 13, 2008 | 01:09 PM
moog5050's Avatar
I had the same code and REP. It was a bad ground.
Old Jul 13, 2008 | 03:08 PM
oldred95's Avatar
Another reason throttle by wire is just pure idiotic. You don't see a throttle cable setting codes now do you? I once asked why and I was told TAC is lighter, less moving parts, less to go wrong. I don't know that I've ever even heard of a throttle cable going bad and a cable weighs what, half a pound maybe. The TAC pedal assembly, all the wiring, the module and so on probably weighs 10-15 pounds. I just don't see the logic. Throttle cable > TAC
metalm0
32
Sep 11, 2024 10:12 PM
GreyChevy
Jul 7, 2015 08:57 PM
2K Silvy
Jun 6, 2015 01:22 PM
darkirish63
May 1, 2015 02:17 PM
foxySS
Apr 6, 2008 12:00 AM
